How to set minimum support for this thing?
November 01, 2014 07:58AM
Dear RepRappers,
how should I set Support material in Slic3r for this Thing?
Dental Valentine
I assume I would only need minimal Support in the middle of the heart, nothing outside, and nowhere else. I tried several Settings but Slicer put Support everywhere. sad smiley
Thanks for all helpful answers smiling smiley
Wolfgang
Re: How to set minimum support for this thing?
November 01, 2014 11:00AM
You could try Cura. It makes lighter support structures I think.
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
November 01, 2014 12:17PM
Hm, will give it a go. With Slicer and default support settings this comes out, see attached. Unusable.
open | download - 2014-11-01 17_06_47-Slic3r.png (10.1 KB)
open | download - IMGP6718small.JPG (407.2 KB)
open | download - IMGP6720small.JPG (476.8 KB)
November 01, 2014 05:55PM
Well maybe because you have your support angle set to 0* Try about 50*-60*
November 01, 2014 06:24PM
Yea support overhang normally a default would be 45 that way it only puts support where the angle in free air is 45 degrees or greater.
November 02, 2014 03:07AM
Thank you, that sort of hint I was looking for. I had not really the right sense how to handle this setting. Will try it, thank you smiling smiley
