Do I need do change my extruder? (Picture)
January 20, 2015 04:58PM
I think the molten filament gets up through the treads, as you can see on the picture. Is this normal?
Sometimes the extruder extruds too little filament, and seams having a hard time getting the filament out. I'm guessing this is because there are some halfmolten filament that is sticking to the filament that wants to come out.
This is what it should like when this happens: [www.youtube.com]
What should I do? Is there any better extruders out there that you can recomend?
Re: Do I need do change my extruder? (Picture)
January 20, 2015 05:02PM
The molten filament is under pressure in the hot end when the extruder feeds more filament. The leakage is common, and can be solved by adding a fiber washer and a thin M6 nut tightening it down onto the hot end.
Here's a photo of mine:
I would highly suggest insulating the hot end as well...
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
January 20, 2015 05:44PM
Thanks for your fast answer! I will try that.
Do you mean that I should insulate the hot end with a m6x32 washer, as on your picture? Do you think that will make it easier for the extruder to extrude the filament in the right speed, and not like in the movie I sent i my last post?
Edited 1 time(s). Last edit at 01/20/2015 05:45PM by filiptheking.
January 20, 2015 06:00PM
Insulating the aluminum block will help keep the heat from radiating to your other parts. On long duration prints, this can lead to the threaded tube becoming too hot, which can reult in jamming or 'noodling' the filament between the extruder gear and the tube. The only part that needs to be hot is the block. Everything above it works better when cool.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
January 22, 2015 09:55AM
I would not use the extra washer, but instead use PTFE threading tape to seal the threads.
It's stuff like this:
[www.youtube.com]
But, unlike in the video, start with just a few windings.
http://www.marinusdebeer.nl/
January 22, 2015 04:42PM
@ MindRealm
Don't you have any problems with the z-nuts falling out?
You have your x-axis ( motormount and idler) upside down.
Hans.
January 22, 2015 06:13PM
No problems at all - they're very tight. I will probably end up installing THESE at some point anyway. I mounted them that way to have all wiring on the right, and didn't want the stepper motor sticking out as in FolgerTech's photos. (I really don't like a bunch of wires showing...)
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
