First print after no activity =blocked head and chewed filament.
January 31, 2015 03:21PM
So twice now after not printing for several days, I have notice that the filament jambs in the hot end and the extruder chews into the filament without pushing it into the hot end.
Should I be removing the filament If I'm not going to print for several days?
Prusa i3
ABS Filament
Re: First print after no activity =blocked head and chewed filament.
January 31, 2015 08:19PM
No need to remove filament after use, pretty sure nobody does this.
Post more about your machine like temperatures you use and what hotend.
February 01, 2015 04:26AM
tmorris9
Prusa i3
Bulldog lite extruder, 0.4m nozzle, Hexagon hotness @ 230c
Hotbed @ 100c
Ano
February 01, 2015 07:22AM
Just to clarify: You have a fan on the hotend cooling the ribs? And after a print job you let this fan
running until you hotend reaches low temperatures? If you switch of the fan, before the hotend
cooled, it could still heat up the ribs enough, to melt the abs in the normally cooled zone, which
would lead to a big blob, that will not be heated the next time, because your fan will be switched
on again on the start of the next print.
Prusa i3 Rework (from Replikeo.com) & original Prusa i3 MK2 (from shop.prusa3d.com) << the MK2 definitely is worth the higher cost!
Print Troubleshooting Guide // Visual troubleshooting guide
February 01, 2015 07:44AM
Yup, printer left on till all fans stop.
Ano
February 01, 2015 08:50AM
Did you try to heat the nozzle up a bit more for the first layers? And when are your fans switching off btw, at which hotend-temp?
Edited 1 time(s). Last edit at 02/01/2015 08:50AM by Ano.
February 01, 2015 10:14AM
Ano
Nope didn't think of that let alone know how too. It heats up to 235 sits there then drops to 232 and starts printing.
Ano
That I don't actually remember but today printing out a duel extruder head so it hasn't had the time to chill.
Mind you, its sat at the rear of the house which has bad heating.
Ano
February 01, 2015 11:12AM
It should be possible to change it under filament settings in slic3r.
Or perhaps change the line #530 in marlin.
#define ABS_PREHEAT_HOTEND_TEMP 240
