Hello,
im new at this forum.
I have googled lots of hours for my problem, but i couldnt find a solution.
The Problem:
I have bought a 12864 Full Graphics LCD for my Prusa i3 Hephestos, but i wont work with any of the instructions i found on the internet.
I use Marlin 1.4 Firmware, it works fine with the standard 16x2 LCD Panel.
As discribed on the reprap wiki i defined the motherboard 33 and REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER. also included the u8glib and also LiquidCrystal-I2C-library.
Im am not a programer and i dont know every command.
I hope you can help.
This is the error i get when i try to compile:
Arduino: 1.6.1 (Windows 8.1), Platine: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Verwende die Bibliothek U8glib im Ordner: C:\Users\morawitz\Documents\Arduino\libraries\U8glib (legacy)
Verwende die Bibliothek Wire im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Verwende die Bibliothek Arduino-LiquidCrystal-I2C-library-master im Ordner: C:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master (legacy)
Verwende die Bibliothek LiquidCrystal im Ordner: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
Verwende die Bibliothek SPI im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\BlinkM.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\BlinkM.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\cardreader.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\cardreader.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ConfigurationStore.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ConfigurationStore.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\digipot_mcp4451.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\digipot_mcp4451.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\LiquidCrystalRus.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\LiquidCrystalRus.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Marlin.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Marlin.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\MarlinSerial.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\MarlinSerial.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Marlin_main.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Marlin_main.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\motion_control.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\motion_control.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\planner.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\planner.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\qr_solve.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\qr_solve.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Sd2Card.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Sd2Card.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdBaseFile.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdBaseFile.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdFatUtil.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdFatUtil.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdFile.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdFile.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdVolume.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\SdVolume.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Servo.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\Servo.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\stepper.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\stepper.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\temperature.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\temperature.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Users\morawitz\Documents\Arduino\libraries\U8glib -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\morawitz\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp -o C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp.o
In file included from C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:101:0:
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\dogm_lcd_implementation.h: In function 'void lcd_implementation_status_screen()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\dogm_lcd_implementation.h:179:7: error: 'blink' was not declared in this scope
if ((blink % 2) && fanSpeed ) u8g.drawBitmapP(9,1,STATUS_SCREENBYTEWIDTH,STATUS_SCREENHEIGHT,status_screen0_bmp);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void lcd_update_button()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:260:54: error: 'lcd_implementation_update_buttons' was not declared in this scope
button_input = lcd_implementation_update_buttons();
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void lcd_update_encoder()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:292:55: error: 'lcd_implementation_update_buttons' was not declared in this scope
encoder_input = lcd_implementation_update_buttons();
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void lcd_enable_button()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:427:54: error: 'lcd_implementation_update_buttons' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void lcd_enable_encoder()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:437:55: error: 'lcd_implementation_update_buttons' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_menu_main()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:580:115: error: 'lcd_implementation_drawmenu_wizard_selected' was not declared in this scope
lcd_implementation_drawmenu_ ## type ## _selected (_drawLineNr, _label_pstr , ## args ); \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:716:5: note: in expansion of macro 'MENU_ITEM'
MENU_ITEM(wizard, "FW info", draw_picture_splash);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:582:102: error: 'lcd_implementation_drawmenu_wizard' was not declared in this scope
lcd_implementation_drawmenu_ ## type (_drawLineNr, _label_pstr , ## args ); \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_menu_filament_load()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:931:47: error: 'lcd_implementation_set_cursor' was not declared in this scope
lcd_implementation_set_cursor(0, 0);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:932:59: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_CF_HEAT_1));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:936:60: error: 'lcd_implementation_print' was not declared in this scope
lcd_implementation_print(LCD_STR_THERMOMETER[0]);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_menu_filament_unload()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1016:47: error: 'lcd_implementation_set_cursor' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1017:59: error: 'lcd_implementation_print_P' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1021:60: error: 'lcd_implementation_print' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_move_x()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\dogm_lcd_implementation.h:33:22: error: 'buttons' was not declared in this scope
#define LCD_CLICKED (buttons&EN_C)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1162:9: note: in expansion of macro 'LCD_CLICKED'
if (LCD_CLICKED) {
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_move_y()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1206:9: note: in expansion of macro 'LCD_CLICKED'
if (LCD_CLICKED) {
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_move_z()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1250:9: note: in expansion of macro 'LCD_CLICKED'
if (LCD_CLICKED) {
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_move_e()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1290:9: note: in expansion of macro 'LCD_CLICKED'
if (LCD_CLICKED) {
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_wizard_level_bed()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1334:55: error: 'lcd_implementation_set_cursor' was not declared in this scope
lcd_implementation_set_cursor(1, 0);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1335:77: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_WIZARD_LEVELBED_0_1));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_level_bed_cooling()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1677:47: error: 'lcd_implementation_set_cursor' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1678:59: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_LB_COOL_1));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1682:60: error: 'lcd_implementation_print' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_wizard_change_filament()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1782:55: error: 'lcd_implementation_set_cursor' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:1783:83: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_WIZARD_CHANGEFILAMENT_0_0));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_set_temperature()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2007:47: error: 'lcd_implementation_set_cursor' was not declared in this scope
lcd_implementation_set_cursor(1, 1);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2008:56: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_NOZZLE));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2009:41: error: 'lcd_implementation_print' was not declared in this scope
lcd_implementation_print(':');
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_speed_printing()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2123:47: error: 'lcd_implementation_set_cursor' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2124:55: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_SPEED));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2125:41: error: 'lcd_implementation_print' was not declared in this scope
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void view_picture_splash()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2164:47: error: 'lcd_implementation_set_cursor' was not declared in this scope
lcd_implementation_set_cursor(1, 6);
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2165:58: error: 'lcd_implementation_print_P' was not declared in this scope
lcd_implementation_print_P(PSTR(MSG_WELLCOME));
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_int3()':
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2268:13: note: in expansion of macro 'LCD_CLICKED'
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2290:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(int, int3, itostr3, 1)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_float3()':
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2291:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(float, float3, ftostr3, 1)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_float32()':
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2292:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(float, float32, ftostr32, 100)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_float5()':
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2293:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(float, float5, ftostr5, 0.01)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_float51()':
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2294:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(float, float51, ftostr51, 10)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_float52()':
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2295:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(float, float52, ftostr52, 100)
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp: In function 'void menu_edit_long5()':
if (LCD_CLICKED) \
C:\Users\morawitz\AppData\Local\Temp\build5661944916098592999.tmp\ultralcd.cpp:2296:1: note: in expansion of macro 'menu_edit_type'
menu_edit_type(unsigned long, long5, ftostr5, 0.01)
Fehler beim Kompilieren.
