First print NEED ADVICE April 23, 2015 01:34PM |
Re: First print NEED ADVICE April 23, 2015 01:40PM |
Re: First print NEED ADVICE April 23, 2015 01:45PM |
Re: First print NEED ADVICE April 23, 2015 01:47PM |
Re: First print NEED ADVICE April 23, 2015 02:43PM |
Re: First print NEED ADVICE April 23, 2015 05:05PM |
Re: First print NEED ADVICE April 23, 2015 05:34PM |
JamesK
Sorry for the bad formatting. It's a link to the calibration guide. I meant, how did the calibration tests go?
Re: First print NEED ADVICE April 23, 2015 05:36PM |
Re: First print NEED ADVICE April 23, 2015 06:11PM |
Re: First print NEED ADVICE April 23, 2015 06:14PM |
ggherbaz
too hot for PLA. reason for the strings between segments, lowered to 195. Also increase retraction settings.
Re: First print NEED ADVICE April 23, 2015 06:16PM |
Re: First print NEED ADVICE April 23, 2015 06:26PM |
Ralphy
yesssss its like whooooooooooooooooooooooooooooooooww
This is intense [reprap.org]
Is all that required to get it right?
Re: First print NEED ADVICE April 23, 2015 08:34PM |
Hephaestus0000
Ralphy
I haven't gone through all of it myself, but it does appear to be the most recommended guide for calibrating your printer.
I, too, don't have a full understanding of that guide either....
(I just want to print obscene things to send to my friends 4500km away. Is that too much to ask!? lol)
Re: First print NEED ADVICE April 23, 2015 08:36PM |
Hephaestus0000
ggherbaz
The Folger Techs don't seem to laminate well below that temp.
I printed some PLA the other night at 210*c and delaminated.
At 195*c it barely seems hot enough to extrude.
Re: First print NEED ADVICE April 23, 2015 08:57PM |
Re: First print NEED ADVICE April 25, 2015 01:56PM |
Re: First print NEED ADVICE April 25, 2015 08:58PM |
Re: First print NEED ADVICE April 30, 2015 10:16PM |
Re: First print NEED ADVICE April 30, 2015 10:31PM |
Re: First print NEED ADVICE April 30, 2015 10:56PM |
Re: First print NEED ADVICE May 01, 2015 09:57AM |
Re: First print NEED ADVICE May 01, 2015 01:25PM |
ggherbaz
In your firmware or LCD screen if you have one. Its a simple rule of 3: actual steps X desired distance ÷ actual distance = new step value. You can put in on the motion selection in the display or in firmware configuration h file.
Re: First print NEED ADVICE May 01, 2015 03:13PM |
Re: First print NEED ADVICE May 01, 2015 03:31PM |
Re: First print NEED ADVICE May 01, 2015 05:55PM |
ggherbaz
Measure your part, if your old steps are for example 80 and your part was supposed to be 10mm but came out 12mm, you do 80X10÷12 the resulting value will be the new steps per mm value that you need to change in configuration h file.
Re: First print NEED ADVICE May 01, 2015 09:01PM |
Re: First print NEED ADVICE May 02, 2015 03:01PM |
ggherbaz
That's right, don't get disappointed if you are still off after the first calibration. It took me few test prints to get it right.
Print also a big hollow cube, don't calibrate only with small parts.
Re: First print NEED ADVICE May 02, 2015 11:18PM |
Re: First print NEED ADVICE May 04, 2015 02:24PM |
Re: First print NEED ADVICE May 04, 2015 02:38PM |
Ralphy
. . . this guy talks about downloading the latest firmware but doesnt mention where he got it. . . .
