The hell skull June 04, 2015 01:27AM |
Re: The hell skull June 04, 2015 05:26AM |
Re: The hell skull June 04, 2015 07:57AM |
Re: The hell skull June 04, 2015 09:17AM |
Re: The hell skull June 04, 2015 09:42AM |
Re: The hell skull June 04, 2015 12:04PM |
Re: The hell skull June 04, 2015 01:46PM |
Re: The hell skull June 04, 2015 01:47PM |
Plasteroid
You could try to cut that stl in some 3D software where it ended and try to print the rest of the piece separately. Then glue. If it ABS plastic, inexpensive ABS juice and it sticks almost even better than original layers. You could try also fan blowing very faintly or enough to the piece (better quality). Or just sand paper.
Re: The hell skull June 05, 2015 03:22PM |
Re: The hell skull June 05, 2015 04:09PM |
ggherbaz
One thing the guy mention in his post is that he printed it without infill or 5% tops, yours look like anywhere from 10 to 15%. Also he used 4 perimeters. Have you tried that way?
Re: The hell skull October 14, 2015 10:14AM |
Re: The hell skull October 15, 2015 04:52PM |
Re: The hell skull October 16, 2015 12:07PM |
Re: The hell skull October 21, 2015 03:55PM |
Try go down in layer hight, a little extra cooling helps too.Quote
thetazzbot
How about the overhangs, where it looks very rough and ugly? I'm getting this on other models. I try to change only one variable at a time when I have these kind of issues. In this case, less flow and lower temp had no effect.
