Top solid layer over and underfilled at the same time
Posted by sungod3k
June 24, 2015 02:13PM
I've gotten good reliability out of my e3d V6 and updated my geared air tripper extruder recently to a non screw based hobbed bolt. It packs a punch now. My machine also got better and now Im seeing an issue I had for a long time.
Im printing on average with 60mms and my perimeters leave nothing to be desired but on the foto I printed with 30mms and I still have gaps in the middle. The slight overextrusion I can explain from my relatively low acceleration of 500 but the gaps shouldnt happen not even at that low speed.
With that error still going there is no way to really calibrate the top level surface to have a homogeneous look and that drives me nuts grinning smiley
Any ideas? Cheers
Edited 1 time(s). Last edit at 06/24/2015 02:37PM by sungod3k.
Re: Top solid layer over and underfilled at the same time
June 24, 2015 10:49PM
most likely you are over-extruding all together. Your infill may look under, but it's ridges caused by the hot end moving thru too much material.
June 25, 2015 03:37AM
Dirty Steve
Can you expand on that? I also should mention that I have 5 top solid layers so that there is not chance of the top most layer sagging down.
June 25, 2015 04:34AM
To me it looks like the infill is printed with gaps between the lines.
Are you sure the line widths for the infill are set correctly as well as the nozzle diameter?
Although even then there should be no gaps like this.
June 25, 2015 07:09AM
Right no matter the width it should close. Im using 0.6-0.8 on a 0.4 nozzle. and I feel the gaps are to big to be filled with 2-3 % of overextrusion.
June 25, 2015 07:36AM
Have you tried a different slicer to check if the problem with the slicing or the printer?
A visual inspection of the code in the preview window of the printsoftware might already show if the lines meet or have gaps.
June 26, 2015 12:49AM
Hey, I currently have this issue as well just recently (smileys with beer)
This issue of mine just came up recently, it doesn't appear at all until I did something that I don't know exactly. I'm not even sure that it is because of my fault smiling bouncing smiley.
I'm using slic3r and I've already tried to tune up every setting I can find in slic3r :
- Print speed 10~100mm/s thumbs down
- Acceleration 1000~9000mm/s^2 thumbs down
- Top solid layer 3~5 layers thumbs down
- Extrusion width 0.24~0.4mm & auto thumbs down
- Cheating with nozzle diameter 0.3~0.4mm thumbs down
- Changing flowrate 0.9~1.1 thumbs down
- Changing steps/mm 110~160steps/mm thumbs down
- New autospeed feature of slic3r thumbs down
- Infill density 10~50% thumbs down
- Various infill pattern thumbs down
- Temperature 210~230 deg C thumbs down
- Layer height 0.12~0.24mm thumbs down
From my observation, it looks like the infill tends to sag, which causes the solid infill above to sag as well, and, consequently, topmost layer becoming what it looks like in picture up above. Because it sags, the top solid infill near the perimeter got squished while it doesn't near the center. If I increase the infill density, it got better. If I set it to total solid infill, it just got perfect. But I don't want to do that as it is a waste of material thus money.
Changing extrusion width won't change a thing since the extrusion will be separated farther away to each other as it is set fatter.
Increasing flowrate will make it fatter without separating farther, but will make it even sags, which is worse.
Decreasing flowrate helps a bit, but it snaps before leveling up, which is futile.
But I remember cheating the nozzle diameter to become smaller helps close the gap, but at the expense of getting the layer scraped off.
HOWEVER
Once I switched to CURA, the GAP CLOSES!! But I still haven't got a good print yet since it still sags. Only the gap closes, the sag persists. I haven't tried to decrease the flowrate yet along with cura.
But it is weird with my case. I have been using slic3r for long and even had variously set the nozzle diameter with 0.3~0.4mm due to false instruction but it always bear good surface finish. It only happen just recently. At first I suspect slic3r as it happen likely after I update it to v1.2.7 experimental. However, updating it to v1.2.9 stable or reverting it to v1.1.7 stable don't change anything. It must happen because of something else.... but what..
Edited 3 time(s). Last edit at 06/26/2015 12:57AM by Vashikovich.
June 26, 2015 04:57AM
That could just mean that we're printing to hot.
Im printing on my new delta so Im constantly changing hard and software, but I looked at my prints from the last months and 50% dont show that pattern.
Im trying kissslicer tonight.
June 27, 2015 07:46AM
I've tried with lower temperature down to 170 deg and still not much difference.
I also retried using cura, and I just came to realization that the tighter gap cura offers is only because it uses thin extrusion width, which actually doesn't play any role in this issue because my biggest problem is the sagginess.
Do your print sags much as well?
Edited 2 time(s). Last edit at 06/27/2015 07:47AM by Vashikovich.
June 27, 2015 08:27AM
Looking with the naked eye I cant see any sagging, but since there is a bit of overlap between the perimeters and the solid infill there is more material to "squish" over, so I cant exclude sagging as a cause.
Yesterday I printed some large model where the error showed up much worse. The gaps appear right after the perimeters, so when the lower layer still has gaps the top most layer still has space to sag and to fill in and is causing gaps again.
http://1.bp.blogspot.com/-F3UAwVovFFA/VY6NLDWPIQI/AAAAAAAACt8/6brVKPbBKwU/s1600/CIMG0675.JPG
http://4.bp.blogspot.com/-Fm2vyBlKV74/VY6NLKfNvpI/AAAAAAAACuA/bdiJVDMxnsU/s1600/CIMG0676.JPG
I get the feeling that this is an matter of overall precision. I have already planned a complete rebuild of my frame in some weeks, because I can imagine that if something is a little bit out of alignment anywhere and the head moves a bit to fast and pulls a line with is it stretches thin and if it then encounters a layer with gaps underneath it, we continue getting gaps.
I will also upgrade to autocalibration, so I hope I get most possible precision.
One more thing: the pressure advance setting could help with the "overextrusion" part. If one manages to get that tuned in, compensation with extrusion multiplier could get much closer to a good result.
June 27, 2015 12:06PM
Looking at your print in a better-angled pictures tells me that your issue and mine are different.
You have a consistent and flat layer throughout the surface. The squish on near the perimeter is normal because of acceleration. The gap is caused by grouping of 2 filaments on each run and thus your nemesis is backlash and it's just it. You only need to tighten your belt or so.
Good luck
June 27, 2015 12:14PM
I agree the squish is most likely acceleration related however
what does that mean? and how does the backlash relate to that?
June 28, 2015 01:59AM
See this visual troubleshooting guide for ultimaker. [support.3dverkstan.se]
I once had this problem, too, and I tightened my belt and voila, it got fixed.
Backlash makes your head shifted a bit on each direction change. Those shift on X and Y combined will likely shift every infill run and make every filament closer to its adjacent filament while farther to its other adjacent filament.
