prusa i3. unable to feed filament into extruder July 01, 2015 10:10PM |
Re: prusa i3. unable to feed filament into extruder July 02, 2015 12:09PM |
Re: prusa i3. unable to feed filament into extruder July 02, 2015 12:14PM |
Re: prusa i3. unable to feed filament into extruder July 03, 2015 01:42PM |
Re: prusa i3. unable to feed filament into extruder July 05, 2015 11:19AM |
Re: prusa i3. unable to feed filament into extruder July 06, 2015 07:17PM |
Re: prusa i3. unable to feed filament into extruder July 07, 2015 11:30AM |
Re: prusa i3. unable to feed filament into extruder July 09, 2015 11:40PM |
jessiebeman
To be honest with you for some reason when I try to operate the printer in manual none of the controls work(except for the homing keys for xyz, and the keys that turn on the heat bed and extruder fan) The temp in the log says that the extruder is reaching the temp needed for printing. You have to put the printer in manual to feed the pla in to the extruder but the manual controls do not work. I went as far as uploading 3d model and letting the printer run through the motions as if it was really printing and everything seems to work fine, all motors are working , but when I manually try to control it (only homing keys work). I cant manually move y forward and back. I cant manually move x left or right. I cant manually move z up and down. I cant manually feed the extruder. I have tried to look through lots of threads on this forum but I cant find anything that sounds similar to my problem.
