Hello,
I'm trying to print some big model (the Corner of Cherry Pi Printer),
and I get a crack at the same place each time I try to print it.
I tried different layer heights, different temps (from 200 to 215 for PLA), print without a fan, with a fan, use higher bed temperatures (60-70).. nothing helps!
There is only one crack, some times it's a little crack, and sometimes it's a big crack, but it's always there, at the same place, and this crack is goes all the layer long, not in a corner.
I thought it might be the model, but netfabb said it's all good.
I measured the filament diameter at some positions, and entered the correct size in Cura.
I have a Rostock 3D printer, and I wasted almost a spool trying to figure out why this is happening.
It never happened before, and I think it's could be a printer related issue because it keeps happening at the same place, only in this model!
I would like to hear some suggestions,
Thank you!
