Configuring Home on Folger Tech i3 August 10, 2015 01:10AM |
Re: Configuring Home on Folger Tech i3 August 10, 2015 04:25PM |
Re: Configuring Home on Folger Tech i3 August 10, 2015 07:06PM |
Re: Configuring Home on Folger Tech i3 August 10, 2015 11:10PM |
deaconfrost
can you post your configuration.h I have a look
I have the Folger Junk i3 myself, or had, it no longer is after all the work been done to make it print without troubles
are you writing the firmware yourself or you using the pre-config one from Folger Tech? a lot aren't correct in that, you need to make lots of changes, and they are probably still using the firmware from 2013, thats the one I got from them anyway, and still the same one on there download link.
link here thats what I've done with mine.
[forums.reprap.org]
I presume you using Marlin_RAMPS_EPCOS_i38 from their link right?
Re: Configuring Home on Folger Tech i3 August 11, 2015 07:32AM |
Re: Configuring Home on Folger Tech i3 August 12, 2015 10:17PM |
Re: Configuring Home on Folger Tech i3 August 12, 2015 10:48PM |
Re: Configuring Home on Folger Tech i3 August 13, 2015 06:17AM |
Re: Configuring Home on Folger Tech i3 August 13, 2015 09:26AM |
Re: Configuring Home on Folger Tech i3 August 13, 2015 12:49PM |
Re: Configuring Home on Folger Tech i3 August 13, 2015 12:57PM |
Re: Configuring Home on Folger Tech i3 August 15, 2015 06:02PM |
Re: Configuring Home on Folger Tech i3 August 24, 2015 06:43PM |
Re: Configuring Home on Folger Tech i3 August 26, 2015 01:36PM |
