Over-Extruding August 25, 2015 11:01AM |
Re: Over-Extruding August 25, 2015 11:35AM |
Re: Over-Extruding August 25, 2015 11:37AM |
Re: Over-Extruding August 25, 2015 06:33PM |
Re: Over-Extruding August 25, 2015 06:45PM |
Re: Over-Extruding August 25, 2015 08:05PM |
Re: Over-Extruding August 26, 2015 12:51PM |
Re: Over-Extruding August 27, 2015 02:57AM |
Re: Over-Extruding August 27, 2015 08:50AM |
Re: Over-Extruding September 17, 2015 02:48PM |
Re: Over-Extruding September 17, 2015 04:14PM |
Re: Over-Extruding September 17, 2015 05:31PM |
Re: Over-Extruding September 17, 2015 09:42PM |
Re: Over-Extruding September 18, 2015 07:50AM |
Rockel83
. . . I took the 10cm strings which I extruded in mid air to check the extruder steps/mm. . .
Rockel83
The filament diameter is 1.78 so this is set correct to.
Re: Over-Extruding September 18, 2015 11:10AM |
alan richard
Rockel83
Nooo.
You measure how far the filament travels thru the extruder alone without the hotend on if possible, not the extruded strings.
I'm not surprised your over-extruding!
-a
Re: Over-Extruding September 18, 2015 12:09PM |
Re: Over-Extruding September 20, 2015 06:00AM |
Re: Over-Extruding September 20, 2015 06:00PM |
Re: Over-Extruding September 20, 2015 06:07PM |
alan richard
One method I use to adjust extrusion amount (saw it on the www somewhere) is to print a small object in 'vase' mode with a single perimeter,
check what the extrusion width should be in the Slicer GCode,
then measure the actual printed wall thickness and use it to tweak the extrusion multiplier.
Re: Over-Extruding September 21, 2015 05:51PM |
imqqmi
I think it's a known issue with slic3r 1.2.8 and 1.2.9 that they extrude much more. If I look at the paths in repetier host in will print two inner infills on narrow walls (like One perimeter and an infill line gets doubled). 1.2.7 is fine and I've stuck with that version. Hopefully it will be resolved in the next iteration.
Re: Over-Extruding November 07, 2015 11:00PM |
Re: Over-Extruding November 08, 2015 12:41AM |
koenejet
Hello,
I'm having the same issue as you, and would like to try your fix. I just need to ask, when you put in the width of .48, was that under 'Default extrusion width', or 'External perimeter', or both? Or all the perimeters, including infill and top solid infill?
Thanks,
Scott
Re: Over-Extruding November 08, 2015 06:06AM |
Re: Over-Extruding November 08, 2015 08:57AM |
Re: Over-Extruding November 08, 2015 05:59PM |
