all kinds of wrongness with this print
Posted by shadowphile
August 26, 2015 08:06PM
I have converted my Kossel Mini to Duet and have been printing simple test parts ok, and the auto-cal looks like it is running well.
Today I started on a large (PLA) part and it is terrible and don't know if it is firmware problem or settings in slicer. It looks like too much speed and/or extrusion width but I can't seem to pull it back enough without getting silly settings.
Here are some pics. I am running .4mm layers. The settings from slicer are at the end.
Things to notice in the pics:
-Second layer perimeter is too fast and seems to segment the corners as well, despite attempting to crank perimeter settings down.
-First layer is not oversized, and its width to 120% so why is there too much in spotty patches?
-Second layers and up are definitely over-extruding but I don't know why.
thanks
edit: added gcode file
pic1
pic2
pic3
gcode file
# generated by Slic3r 1.2.9 on Wed Aug 26 16:49:12 2015
avoid_crossing_perimeters = 1
bed_shape = 74.5891x7.83963,73.3611x15.5934,71.3292x23.1763,68.5159x30.5052,64.9519x37.5,60.6763x44.0839,55.7359x50.1848,50.1848x55.7359,44.0839x60.6763,37.5x64.9519,30.5052x68.5159,23.1763x71.3292,15.5934x73.3611,7.83963x74.5891,0x75,-7.83963x74.5891,-15.5934x73.3611,-23.1763x71.3292,-30.5052x68.5159,-37.5x64.9519,-44.0839x60.6763,-50.1848x55.7359,-55.7359x50.1848,-60.6763x44.0839,-64.9519x37.5,-68.5159x30.5052,-71.3292x23.1763,-73.3611x15.5934,-74.5891x7.83963,-75x0,-74.5891x-7.83963,-73.3611x-15.5934,-71.3292x-23.1763,-68.5159x-30.5052,-64.9519x-37.5,-60.6763x-44.0839,-55.7359x-50.1848,-50.1848x-55.7359,-44.0839x-60.6763,-37.5x-64.9519,-30.5052x-68.5159,-23.1763x-71.3292,-15.5934x-73.3611,-7.83963x-74.5891,0x-75,7.83963x-74.5891,15.5934x-73.3611,23.1763x-71.3292,30.5052x-68.5159,37.5x-64.9519,44.0839x-60.6763,50.1848x-55.7359,55.7359x-50.1848,60.6763x-44.0839,64.9519x-37.5,68.5159x-30.5052,71.3292x-23.1763,73.3611x-15.5934,74.5891x-7.83963,75x0
bed_temperature = 0
before_layer_gcode =
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 0
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 0
dont_support_bridges = 1
duplicate_distance = 6
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors\n
external_fill_pattern = rectilinear
external_perimeter_extrusion_width = 90%
external_perimeter_speed = 40
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 1
fan_below_layer_time = 60
filament_colour = #FFFFFF
filament_diameter = 2.95
fill_angle = 45
fill_density = 0%
fill_pattern = honeycomb
first_layer_acceleration = 0
first_layer_bed_temperature = 0
first_layer_extrusion_width = 120%
first_layer_height = 0.4
first_layer_speed = 65%
first_layer_temperature = 205
gap_fill_speed = 0
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 100%
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 15%
infill_speed = 80
interface_shells = 0
layer_gcode =
layer_height = 0.4
max_fan_speed = 100
max_print_speed = 200
max_volumetric_speed = 0
min_fan_speed = 80
min_print_speed = 10
min_skirt_length = 10
notes =
nozzle_diameter = 0.4
octoprint_apikey =
octoprint_host =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 130%
perimeter_speed = 60
perimeters = 1
post_process =
pressure_advance = 0
raft_layers = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 2
retract_length_toolchange = 10
retract_lift = 0.5
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 30
seam_position = aligned
skirt_distance = 7
skirt_height = 1
skirts = 5
slowdown_below_layer_time = 20
small_perimeter_speed = 30
solid_infill_below_area = 40
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 80%
solid_infill_speed = 40
spiral_vase = 0
standby_temperature_delta = -5
start_gcode = G1 Z5 F5000 ; lift nozzle\n
support_material = 0
support_material_angle = 0
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 100%
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = pillars
support_material_spacing = 2.5
support_material_speed = 50
support_material_threshold = 0
temperature = 205
thin_walls = 1
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 40
top_solid_layers = 0
travel_speed = 130
use_firmware_retraction = 0
use_relative_e_distances = 0
use_volumetric_e = 0
vibration_limit = 0
wipe = 0
xy_size_compensation = 0
z_offset = 0
Edited 1 time(s). Last edit at 08/26/2015 08:09PM by shadowphile.
Re: all kinds of wrongness with this print
August 27, 2015 09:20AM
First thing i see is your nozzle size and height are the same. That won't work. Try a layer height of no more the .3.
Edited 1 time(s). Last edit at 08/27/2015 09:21AM by cat.farmer.
