What is a good example of a properly printed side wall? September 17, 2015 06:28PM |
Re: What is a good example of a properly printed side wall? September 17, 2015 09:23PM |
Re: What is a good example of a properly printed side wall? September 17, 2015 09:30PM |
Re: What is a good example of a properly printed side wall? September 17, 2015 10:54PM |
Thank you very much for those examples. Now I feel like I can move on and focus on things like layer height.Quote
AlexY
Your layer alignment looks good, though the wavy pattern shouldn't be there normally. The layer lines you see are typical of larger layer heights and nothing to worry about. If you want a smoother finish, use 0.2mm, 0.1, or even lower layer heights, but the prints will take longer to complete.
Downunder35m
I agree, looks good in general.
The misalignment could be from loose belts, bad layer adhesion (temp too low) or even extruding problems.
I would check with a lower speed to rule out extruder and temp first.
If the print looks much better check the belt tension and if your X-carrier or build platform are loose somewhere.
To find the right temp for a filament I do a bridging test.
If the filament drops the temp is too high, if the supporting pillars break upon bending them the temp is too low causing layer adhesion problems.
Re: What is a good example of a properly printed side wall? September 18, 2015 05:42AM |
Re: What is a good example of a properly printed side wall? September 18, 2015 07:10PM |
Downunder35m
If the scrw comes loose on a thread try thread locker or a locking nut instead.
Otherwise, instead of epoxy use hot glue sticks - if you have to you can remove the stuff again, epoxy will be next to impossible to remove.
