XY repeatability problems
October 05, 2015 08:54PM
hello,
I'm using a mendel i2. things have been going well until this past weekend.
I did a pretty nice t-rex skull and then I started getting really bad prints.
It started with this:
which is weird because it cleaned itself up. I didn't do anything and it started working.
now everything looks like the bottom part of the print in the pic.
I've checked pulley set screws, belt tension, jerk is set to 20mm/sec.
I have tried adjusting flow rate. I'm at a loss for what to do next.
any advice is appreciated.
Re: XY repeatability problems
October 05, 2015 09:58PM
Check for anything that might be catching... a fan shroud or wire or something touching the bed or the X or Y axis mechanism?
Try a cube test print to see if you can isolate the problem to either the X or Y axis.
Check for play in the X and/or Y axes. Check the screws holding the printer together, motor attachment screws, etc... they loosen too.
If you're using auto-leveling, also check the Z axis.
October 06, 2015 10:17AM
well, I made sure everything was tight. it was.
I looked for anything catching or dragging. didn't find anything.
then in a hail Mary attempt, I greased the rails.
problem went away.
decent prints now.
thanks for the help.
October 07, 2015 09:47AM
well that was short lived!
printed 2 pieces and now it's back to the way it was.
I have noticed that my entire hot end moves. like, (when it's cold) I can wiggle the nozzle by 1 or 2 millimeters.
the connection between the heatsink and the wade's extruder is not tight.
is this normal? if not, any ideas on how to make this tighter?
thanks
October 07, 2015 10:12AM
Maybe place a shim or washer between the hotend and extruder.
October 07, 2015 11:22AM
It's definitely not normal. What hot end is it? E3D is always pretty tight, and if it's worn out it's easily and cheaply replaceable by buying a new heat break, heater block and or nozzle.
If your hotend contains PEEK, it may have run too hot and the nozzle may be loose. You'd need to replace the PEEK tube and put a fan on it, or to permanently fix the issue I'd get an all metal hot end.
