Is it Wobble? Banding? [SOLVED] October 18, 2015 04:35AM |
Re: Is it Wobble? Banding? October 18, 2015 05:47AM |
Re: Is it Wobble? Banding? October 18, 2015 05:56AM |
Re: Is it Wobble? Banding? October 18, 2015 06:46AM |
Re: Is it Wobble? Banding? October 18, 2015 07:00AM |
Re: Is it Wobble? Banding? October 18, 2015 07:06AM |
cristian
Do you use auto bed leveling? In that case, does the banding occur if you disable it?
Or do you use a geared extruder? In that case, is the banding the same if you print with infill?
the_digital_dentist
If the part starts to wobble because it isn't firmly attached to the bed the wobble will get worse the taller the part gets. Are they staying stuck to the bed? Can you see the part wobbling as it prints?
sarf2k4
Can you try put some kind of light and see the layers? from what I know on banding, on specific layer the plastic somewhat 'stretched' or something, I don't know if this helps but worth a shot
Re: Is it Wobble? Banding? October 18, 2015 07:13AM |
Re: Is it Wobble? Banding? October 18, 2015 07:19AM |
Re: Is it Wobble? Banding? October 18, 2015 07:48AM |
Re: Is it Wobble? Banding? October 18, 2015 08:05AM |
Re: Is it Wobble? Banding? October 18, 2015 08:12AM |
Re: Is it Wobble? Banding? October 18, 2015 08:17AM |
Re: Is it Wobble? Banding? October 18, 2015 08:43AM |
Re: Is it Wobble? Banding? October 18, 2015 09:42AM |
Re: Is it Wobble? Banding? October 18, 2015 09:50AM |
Re: Is it Wobble? Banding? October 18, 2015 11:41AM |
