Re: Edges of recengular shapes are OK, but circles are disaster November 29, 2015 04:02PM |
Are you sure the Z-axis runs as it should? By the even displacements it looks as if the axis/bed is being forced askew and then snaps back. Probably every full revolution of your ball screw. Like every 8th or 10th mm or something like it?Quote
usen
Downunder35m
You have to measure what comes out of the extruder and adjust the stepping accordingly.
Works best with the cold extrusion prevent disabled in the firmware as you can play back and forth without the hotend and wasting filament.
Mark the filament and extrude 10mm - measure it.
It is not 10mm +-0.3mm already adjust the stepping a bit.
Extrude 30mm and check again.
If required adjust stepping.
Extrude 50mm and check.
Adjust stepping, check again, adjust stepping until you are spot on.
I arranged extruder by changing M97. Extruder extrudes exactly what I want. I printed a new calibration cube and results are below. There are leaps when it fills inner and wall, as you see. And corners are not good, not parallel or smooth.
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 06:15AM |
Paul Wanamaker
I think your primary issue is with extrusion, there are multiple indicators:
- Gaps in printing
- That diagonal pattern that you see, with blobbing. I believe this is caused by a slight temporary underextrusion on the previous layer, and when the next layer goes over that spot it doesn't quite have enough foundation to stick to, and so a blob forms that eventually sticks a short distance later. Then on the next layer the blob sticks to the beginning of the lower blob, and so it builds up at an angle.
- Don't trust that your hot-end thermistor is exactly right. Try slightly higher and lower temps to see what that particular filament needs to flow correctly.
- As stated this could also be caused by some blockage - pull the filament out while the hot end is cooling and it could remove it.
- Watch the extruder temp while it's printing - is it consistently at the right temp? If not you may need to do a PID calibration.
- Watch the heatbed temp as well.
- Make sure the filament drive gear is not getting clogged.
- You can also experiment with a slightly wider or narrower extrusion width to see what your extruder likes, or a slightly taller layer height.
[Edit - more]
- Make sure the extruder is clamping the filament securely enough
- Put marks on the extruder stepper shaft and whatever it's connected to -to make sure it's not slipping (flat ground on shaft)?
- As stated previously - watch it the extruder gear carefully to see if it is slipping back. I think it's a temp issue tho.
There is a very evident repeating wave pattern in the perimeter.
- You can measure the distance. Is this distance related to the ball screw's pitch?
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 08:08AM |
usen
->> I realized that my hot-end thermistor measured wrong temperature. I changed the thermistor and covered with capton tape. I see 208 centigrade degree in the webinterface (GUI), but I measure about 230 centigrade degree with multimeter. Previous printing parts in this page are printed 245 centigrade degree in GUI, but I printed 277 centigrade degree. I realized 2 days ago.
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 10:52AM |
dc42
usen
Sounds like you have the wrong B value in your M305 P1 command in config.g. What thermistor are you using, and what B value?
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 11:03AM |
What do you thing about this design: Bernis Simple Extruder?
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 11:21AM |
usen
dc42
usen
M305 P1 T100000 R4700 B3950
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 11:45AM |
dc42
usen
dc42
usen
And what thermistor are you using? Are you sure it has a B value of 3950? For example, the thermistor used by E3D in their hot ends has a quoted B value of 4267, although 4388 is more accurate at typical hot end temperatures. Using too low a B value will make the firmware report values that are lower than actual.
Re: Edges of recengular shapes are OK, but circles are disaster November 30, 2015 12:18PM |
Re: Edges of recengular shapes are OK, but circles are disaster December 01, 2015 09:24AM |
Re: Edges of recengular shapes are OK, but circles are disaster December 01, 2015 09:37AM |
Re: Edges of recengular shapes are OK, but circles are disaster December 01, 2015 11:06AM |
Re: Edges of recengular shapes are OK, but circles are disaster December 01, 2015 11:34AM |
dc42
What hot end is that? I don't recognise it. Shouldn't there be cool air blowing over the fins?
The varying temperature could mean that extrusion is jerky, which would also explain your print quality issues.
Re: Edges of recengular shapes are OK, but circles are disaster December 01, 2015 11:56AM |
Downunder35m
Ususally you get infills like that if a rectangular infill pattern is selected and he infill speed is far too high.
This causes the filament to only bind to the cross sections without forming a bridge between them.
Either reduce the infill speed and / or try a lower layer height.
Re: Edges of recengular shapes are OK, but circles are disaster December 01, 2015 07:23PM |
Re: Edges of recengular shapes are OK, but circles are disaster December 02, 2015 04:19AM |
Downunder35m
Depending on the material and part I print the solid infill speed is between 20 and 60mm/s, normal infill again depending on the material between 30 and 100mm/s.
Giving you my settings would not help as your machine is different
Only a proper calibration with some test to check the max possible speeds will help you.
Re: Edges of recengular shapes are OK, but circles are disaster December 02, 2015 04:34AM |
Re: Edges of recengular shapes are OK, but circles are disaster December 16, 2015 05:26AM |
Re: Edges of recengular shapes are OK, but circles are disaster December 26, 2015 01:50PM |
