Problem with extrusion, too few![]() January 06, 2016 11:11AM |
Re: Problem with extrusion, too few![]() January 06, 2016 05:51PM |
Re: Problem with extrusion, too few![]() January 06, 2016 07:18PM |
Re: Problem with extrusion, too few![]() January 06, 2016 07:32PM |
Re: Problem with extrusion, too few![]() January 07, 2016 09:36AM |
frankvdh
Did you calibrate your extruder? There can be 10% variation in steps/mm from standard. Also filament can vary by 10% from 1.75mm... you should measure it and adjust the slicer settings correspondingly.
E3D hotends (and especially cheap Chinese "copies") don't like retraction. This can cause the 'tak tak' problem. Make sure that the retraction is set to less than 1mm in your slicer.
If the nozzle is too hot, it can also cause this problem. I print PLA at 190. The cooling fan on your hot end should be on all the time.
Increasing the acceleration of the extruder stepper is likely to make the problem worse, not better. If you try to accelerate a stepper more than it can manage, it will skip (tak, tak).
I don't think this is the problem, but if your nozzle is too close to the bed, it can also cause jams.
Try using the extrude command in your user interface to extrude when the nozzle is up in the air. How well does that work?
Yes it does without problemsQuote
Downunder35m
Tak Tak usually means you are loosing steps.
Don't know your extruder but if you can push by hand it should not have any problems at all.
Place the nozzle at first layer height on the plate and extrude 5 or 10mm - it should all ooze out around the nozzle.
If it does not and your extruder starts clicking you have a problem with it.
Kered124
1: Check and adjust the Z- Gap between your nozzle and the print bed-use a piece of paper as a spacer.
2: Check your Hobbed gear on the extruder motor to make sure it isn't packed full of chipped off filament.
3: Watch the gear as you try to print- does it stop? Does is spin too quickly and filament doesn't move? If it does either of those, Its probably an issue with your tension on the filament.
Re: Problem with extrusion, too few![]() January 07, 2016 10:58AM |
Re: Problem with extrusion, too few![]() January 07, 2016 11:52AM |
Re: Problem with extrusion, too few![]() January 07, 2016 03:46PM |
Salvatore94
What do you mean with tension on the extruder? The motor's voltage?Quote
sarf2k4
It is either the currents supplied from the step stick is insufficient or the tension is too strong on the extruder
Re: Problem with extrusion, too few![]() January 07, 2016 11:59PM |
Re: Problem with extrusion, too few![]() January 08, 2016 03:14AM |
Re: Problem with extrusion, too few![]() January 08, 2016 09:02AM |
How can i verify it?Quote
Downunder35m
Depending on your hotend design it is quite possible that your melting chamber is much wider in diameter than the cold end / teflon tube.
Especially when printing with the correct emperature (that means not too hot) those systems tend to fail as the plastic forms a blob in the lower bit of the telfon tube, or the cold end itself on an all metal design.
In such cases it is often easier to buy a cheap knock off hotend to have a direct flow to the nozzle.
This means the inside diameter of the the system does not change until reaching the nozzle itself.
I've tried and the motor does "tak tak" when i extrude 5mm before retracting, but only sometimes, after retracting it doesn't make noiseQuote
frankvdh
Adding to what the previous guy said... it's important to properly assemble the hot end. Otherwise you also get a large diameter chamber.
I've posted thee process several times here, but if you can't find it, let me know and I'll post it again.
Re: Problem with extrusion, too few![]() January 08, 2016 03:49PM |
Re: Problem with extrusion, too few![]() January 09, 2016 05:15AM |
