Terrible ABS Layer Bonding January 27, 2016 09:04PM |
Re: Terrible ABS Layer Bonding January 27, 2016 09:22PM |
Re: Terrible ABS Layer Bonding January 27, 2016 09:36PM |
Re: Terrible ABS Layer Bonding January 27, 2016 10:04PM |
No, setting the nozzle size to .6 will not have the desired result. Take your extrusion width and multiply by shell layers, then in cura set shell thickness to that number. For example .3 nozzle, 120% extrusion width, 3 shells would be .36x3 = 1.08 shell thickness. The box will turn yellow, and the software will complain, but that will achieve what you want in terms of fattening up perimeter traces.Quote
JamesK
The default answer for ABS is to use an enclosure to increase the ambient temperature, but as well as printing hotter, you can also try printing slower and wider. I don't have an enclosure (yet), and print ABS at 260 and 30 mm/s which seems to work for all but the biggest prints. I don't think cura has an explicit way of setting the extrusion width, but they would have to base it off the nozzle size, so try setting 0.6mm for nozzle size and see if that helps. Having said all that, your benchy looks pretty good. You might find that by the time you get the layer bonding sorted it introduces some other problems.
Re: Terrible ABS Layer Bonding January 27, 2016 10:30PM |
Re: Terrible ABS Layer Bonding January 28, 2016 02:55AM |
Re: Terrible ABS Layer Bonding January 28, 2016 09:24AM |
Hit the close button and use a different slicer? I used cura a lot when I started, but it's level of user control is not high. This seems to be on purpose in order to make it easier for people to use, and I understand that. But for me the answer was to switch slicers. They all have their faults.Quote
JamesK
Interesting. But you need to fatten up all traces, not just perimeters - how do you go about that in cura?
Re: Terrible ABS Layer Bonding January 28, 2016 09:36AM |
Re: Terrible ABS Layer Bonding January 28, 2016 09:49AM |
Re: Terrible ABS Layer Bonding January 29, 2016 06:17AM |
Re: Terrible ABS Layer Bonding January 29, 2016 05:10PM |
Re: Terrible ABS Layer Bonding January 30, 2016 08:44AM |
Re: Terrible ABS Layer Bonding January 30, 2016 10:26AM |
Re: Terrible ABS Layer Bonding January 30, 2016 10:45AM |
