Shifting walls only where travel moves are...
Posted by davidbananas999
February 11, 2016 06:35PM
Its hard to show everything with just two pictures, but the travel moves line up almost perfectly with the part of the print that buldges out a little. Any ideas? I use adjustable belt tensioners and have checked those.
Re: Shifting walls only where travel moves are...
February 11, 2016 09:48PM
just ran through esteps/mm and i was at 680 and should have been at 720. Testing now.
EDIT:
same problem
Edited 1 time(s). Last edit at 02/11/2016 10:25PM by davidbananas999.
February 12, 2016 01:02AM
Hi David,
We can only guess what's causing this with the limited info provided (we don't know anything about your printer). Perhaps something is binding. If you look inside the object, is it shifted towards the outside also?
Here's some general info that will help to diagnose this issue
There are a lot of things that could cause this. I've noted a few of them here: Shifted Layers / Offset Layers / Missed Steps
With more info we may be able to help.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
February 12, 2016 06:21AM
If it's shifting only on travel moves, try turning down the travel speed. Otherwise, turn down acceleration.
February 12, 2016 07:02AM
prusa i3 with e3d v6 hot end
60mm/s perimeter speed
0.3mm nozzle
0.3mm layer height
Repetier with Slic3r
1.75mm pla
210 degrees C ext
80 degrees C bed
not sure about the firmware, havent changed anything from default prusa i3 from hictop
This is the printer I upgraded
Edited 1 time(s). Last edit at 02/12/2016 12:31PM by davidbananas999.
February 12, 2016 12:54PM
I read over the links that were posted and I think it may be under powered motor. The last major hardware thing I did was turn it down due to overheating. It was about a week ago though, but maybe It hasent been noticeable until this particular print. Adjusting and testing now...will post results.
February 12, 2016 05:49PM
I was reading the settings you used.
Just a note about the layer height - the rule of thumb is for layer height < 80% of nozzle diameter. This is for proper layer adhesion.
Extrusion width is recommended to be between 1.04 and 1.7x nozzle diameter.
