Print quality degrades after fist few layers/ sort time
Posted by DerpThing
March 02, 2016 06:44PM
My printer has been printing very well in till to day. I printed out a marven and it looked very bad. I have printed a vase and done it many time to try to find the problem, but i can not find it. I have a photo of what it is doing. how do i fix this?
Edited 2 time(s). Last edit at 03/02/2016 08:50PM by DerpThing.
open | download - My Snapshot50.jpg (34.3 KB)
Re: Print quality degrades after fist few layers/ sort time
March 03, 2016 08:07AM
You have active print cooling? Because this looks to me to be too much heat, though it could also be the model that you are trying to print
Also, Is this pla or abs? And what temps you printing at?
March 03, 2016 04:55PM
I do not have any active cooling yet, but i will print one out soon. And i have been printing my PLA at 195
March 03, 2016 06:16PM
I have made my teps to 185c and i see no improvement
March 03, 2016 09:46PM
Try blowing a SMALL fan across the bed after the first layer goes down.
March 06, 2016 01:09PM
if your printing pla active cooling on the object, i have mine coming on after the first layer get a fan on it you'll see the improvement straight away
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
March 07, 2016 10:35AM
What does the bottom of the bottom layer look like?
Also, I would like to expand on DaGameFace's suspicion of too high of a temp...
Check and make sure that the thermistor is not broken, or reporting temps too low. If it has partially come out of the hotend (EXTREMELY BAD FIRE HAZARD), this would cause the hot end to get WAY hot before the thermistor registers the target temp. What about a heated bed? the whole part does look a bit soggy, so maybe the bed has the same thermistor problem or is just too hot?
Edited 1 time(s). Last edit at 03/07/2016 10:38AM by Montiey.
Master Tinkerer
