do you cool or heat a pla print? March 12, 2016 07:46AM |
Re: do you cool or heat a pla print? March 12, 2016 08:54AM |
Re: do you cool or heat a pla print? March 12, 2016 02:40PM |
Re: do you cool or heat a pla print? March 15, 2016 06:47AM |
Re: do you cool or heat a pla print? March 15, 2016 03:39PM |
I have seen it done mostly with old Mendel printers. It can work.Quote
friarfish
Anyone tried mounting a couple of 90mm fans or so on the frame so they
blow on the bed? I suspect this isn't an ideal solution.
Re: do you cool or heat a pla print? March 16, 2016 11:48AM |
Re: do you cool or heat a pla print?SOLVED March 17, 2016 07:33AM |
Re: do you cool or heat a pla print? March 23, 2016 07:44PM |
Re: do you cool or heat a pla print? March 24, 2016 11:19AM |
Re: do you cool or heat a pla print? March 26, 2016 05:24AM |
Re: do you cool or heat a pla print? March 28, 2016 08:23AM |
Re: do you cool or heat a pla print? March 28, 2016 08:58AM |
elkoreas
sorry but what temperatura and speed work better for PLA, i cant print with a good quality, for this model i use layer h. .3mm, extruder for the first layer at 230 °C an for the rest at 210 °C and the speed for perimeters 40, infill 60, what do you suggest
