z axis or y axis problem
Posted by garibardi1011
March 31, 2016 08:43AM
Hi ;
What's the problem appear, but the standard error of the z-axis gives the design pressure do you think I got the printer in the y-axis of my own design? Thank you
Video link: [youtu.be] Youtube
Re: z axis or y axis problem
March 31, 2016 01:15PM
Bent z axis threaded rod by the looks
April 01, 2016 04:33AM
DaGameFace
Thank you. but there is no problem in the engine shaft and the gap in the y-axis and x-axis joints . Is it a problem that the trapezoidal spindle shaft on the same axis ?
Edited 1 time(s). Last edit at 04/01/2016 05:32AM by garibardi1011.
April 01, 2016 09:02AM
Like many Prusa-like designs, you have no structural component on the X-axis, so the linear guides have to do double duty. How far do the smooth rods recess into the Z carriages? If they don't extend most of the way across the carriages it is likely that you have significant amounts of flex in the X axis, mostly in the Y direction, as well as the usual twisting of the axis that plagues this layout. What diameter are the smooth rods? The standard 8mm smooth rod has a remarkable amount of flex to it. If you hold a Z carriage in each hand, can you flex the X axis back and forwards by twisting the carriages? If so, it's time to redesign your X axis for more rigidity. Flex couples are next to impossible to get well aligned, so unless the Z and X axes are extremely robust the off-centre rotation will force the head out of position.
