Can't figure out extrusion problem May 04, 2016 07:46PM |
Re: Can't figure out extrusion problem May 04, 2016 10:38PM |
Re: Can't figure out extrusion problem May 05, 2016 05:19AM |
Re: Can't figure out extrusion problem May 05, 2016 07:49AM |
Re: Can't figure out extrusion problem May 05, 2016 08:17AM |
Re: Can't figure out extrusion problem May 05, 2016 08:33AM |
Re: Can't figure out extrusion problem May 05, 2016 08:43AM |
Re: Can't figure out extrusion problem May 05, 2016 08:48AM |
Re: Can't figure out extrusion problem May 05, 2016 10:47AM |
Re: Can't figure out extrusion problem May 05, 2016 10:53AM |
Re: Can't figure out extrusion problem May 05, 2016 10:44PM |
Re: Can't figure out extrusion problem May 06, 2016 06:48AM |
Re: Can't figure out extrusion problem May 06, 2016 09:41AM |
Re: Can't figure out extrusion problem May 06, 2016 06:22PM |
Re: Can't figure out extrusion problem May 06, 2016 10:01PM |
Re: Can't figure out extrusion problem May 06, 2016 10:13PM |
Re: Can't figure out extrusion problem May 06, 2016 10:50PM |
Re: Can't figure out extrusion problem May 07, 2016 07:40AM |
Re: Can't figure out extrusion problem May 07, 2016 08:37AM |
Re: Can't figure out extrusion problem May 07, 2016 08:52AM |
sergeys
Some context on how picture was taken: I raised hot end ~80mm, then took a picture looking up from heated bed, about 45 degree angle, looking up. Aluminum heater block is very hot, 180C. While the nozzle itself is only 69C. So the nozzle is much cooler than the block. There is a theory that nozzle does not radiate infrared as aluminum. I'll check tomorrow in different settings, but I'm pretty sure that's not correct.
Re: Can't figure out extrusion problem May 07, 2016 11:03AM |
Re: Can't figure out extrusion problem May 07, 2016 11:17AM |
Re: Can't figure out extrusion problem May 07, 2016 12:58PM |
Re: Can't figure out extrusion problem May 10, 2016 08:07PM |
Re: Can't figure out extrusion problem May 10, 2016 09:04PM |
Re: Can't figure out extrusion problem May 10, 2016 10:19PM |
Re: Can't figure out extrusion problem May 11, 2016 08:41AM |
Re: Can't figure out extrusion problem May 11, 2016 11:33AM |
Re: Can't figure out extrusion problem May 11, 2016 11:45AM |
Re: Can't figure out extrusion problem May 12, 2016 08:48PM |
