ramps 1.4 ( d08 - d10 no respond)
May 23, 2016 12:25AM
my setup
QU-BD one up
ramps 1.4
repetier 1.6
i just setup my one up in repetier 1.6 and was trying to make sure every thing works right before a test print.
all the steppers work fine. the fans work. the themister works and shows temp. as soon as i turn on the extruder hot end nothing?.
here is the log
20:41:43.253 : OpenGL version:4.0.0 - Build 10.18.10.4276
20:41:43.253 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
20:41:43.253 : OpenGL renderer:Intel(R) HD Graphics
20:41:43.253 : Using fast VBOs for rendering is possible
20:41:48.663 : Printer reset detected - initalizing
20:41:48.663 : start
20:41:48.663 : echo:Marlin 1.0.3
20:41:48.663 : echo: Free Memory: 5210 PlannerBufferBytes: 1232
20:41:48.679 : echo:Hardcoded Default Settings Loaded
20:41:48.679 : echoconfused smileyteps per unit:
20:41:48.679 : echo: M92 X88.89 Y88.89 Z1511.81 E136.61
20:41:48.679 : echo:Maximum feedrates (mm/s):
20:41:48.679 : echo: M203 X500.00 Y500.00 Z5.00 E45.00
20:41:48.679 : echo:Maximum Acceleration (mm/s2):
20:41:48.679 : echo: M201 X5000 Y5000 Z100 E10000
20:41:48.679 : echo:Accelerations: P=printing, R=retract and T=travel
20:41:48.679 : echo: M204 P5000.00 R5000.00 T5000.00
20:41:48.695 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
20:41:48.695 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
20:41:48.695 : echo:Home offset (mm):
20:41:48.695 : echo: M206 X0.00 Y0.00 Z0.00
20:41:48.695 : echotongue sticking out smileyID settings:
20:41:48.695 : M301 P24.95 I2.42 D64.37
20:41:48.710 : M304 P10.00 I0.02 D305.40
20:41:48.710 : echo:Filament settings: Disabled
20:41:50.060 : FIRMWARE_NAME:Marlin V1.0.2; FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Q3d One UP EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
20:41:50.076 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
20:41:50.076 : echo:Active Extruder: 0
i can up load an image of my setting if that helps?
Edited 2 time(s). Last edit at 05/23/2016 04:13AM by 3dfbomb.
Re: ramps 1.4 ( d08 - d10 no respond)
May 23, 2016 05:14PM
24 views and no replysad smiley looks like i have my answer. i am going to have to get a new board!
May 23, 2016 07:19PM
i have in fact found out that i have a defective ramps board so case closed!!!!!!
May 23, 2016 09:40PM
Ah, well done. What was wrong with it? I was a bit stumped by all three outputs not working - couldn't really think of anything to suggest.
