Need help, random stopping of prints! (i3)
July 14, 2016 12:32PM
I had completed about 50 hours of printing before encountering this ‘Jam’. Very weird that it’s popped up out of the blue like this, but I can’t seem to shake it and hope you guys might be able to provide some insight.
Not sure if it’s related, but after the first incidence of the jam, the mk2b heatbed could not reach temperatures higher than say 70 degrees C, even after multiple PID autotune attempts. I ended up replacing it to help troubleshoot the issue. I’m wondering if maybe the first jam caused the hotend to plunge or something and crack (non-visibly) the heatbed pcb or something. Still don’t know.
Anyways, the problem that remains is a jamming issue. Every print now encounters this and sending the same job twice will not yield a jam at the same exact spot. I have used multiple slicing programs gcode processing programs to eliminate that potential error but still get the same result regardless. I had also thought that it might be related to my printer running via usb to a windows 10 computer, however the fact that previous prints (50hrs) were working, on top of me not able to resume the print once 'jammed' through the pronterface or simplify3d interface leads to me believe this might be a hardware issue. The g-code processing and data feed does not provide any information when it hits the jam, no error codes or anything, from the computer’s perspective it believes the job is still printing. Any chance any of you have encountered this before or suggestions in working this thing out?
Video of the jam: [www.youtube.com]
The sound is important as this is the one thing that is consistent every time.
SPECS:
GT2 Belt driven X and Y axis
e3d v6 Hot end
Mk2b Heated Bed
NEMA17 Stepper motors with 60oz in torque
Arduino MEGA 2560 with RAMPS 1.4 and A4988 stepper drivers
400 Watt 12v power supply
Mechanical endstops with LED
Thanks in advance
Re: Need help, random stopping of prints! (i3)
July 14, 2016 12:50PM
Power failure. Your power supply is shutting down since everything stops, including the flickering led for the hotend.
It also could also the the PTC fuses tripping.
Edited 1 time(s). Last edit at 07/14/2016 12:51PM by stephenrc.
July 14, 2016 07:42PM
Great catch Stephenrc! Should I go ahead and purchase a new power supply matching the previous specs or go bigger if that exists? or perhaps troubleshoot what I've got and repair it?
July 15, 2016 09:50AM
I never hurts to have a spare. I use these: [www.trcelectronics.com]
If you have this style of a power supply, make sure the fan works and open it up to check for bad solder joints.
July 15, 2016 02:46PM
Backup huh, do these typically have a running lifespan? If so, what might I expect? assuming i don't a lemon again
July 31, 2016 05:20PM
Well, I installed a new power supply and it's still exhibiting the same issue. Any other ideas?
July 31, 2016 05:44PM
What is your powersupply exactly? Is it an ATX one? A laptop powersupply? Or something else? I know there was a lot of issues with ATX powersupplys not working properly over an extended period of time due to some of the "powersaver" features some of them had.
August 05, 2016 01:19PM
Its a S-400-12
AC INPUT: 110/220v +/-15%
DC OUTPUT: 12V 33A
Nearly Identical:
[www.kk6jyt.com]
Are you cooling your RAMPS at all?
