Gaps between perimeter and infills September 02, 2016 08:56AM |
[filament:0.3 nozzle] bed_temperature = 60 bridge_fan_speed = 100 cooling = 1 disable_fan_first_layers = 3 extrusion_multiplier = 1 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #FFFFFF filament_diameter = 3 first_layer_bed_temperature = 65 first_layer_temperature = 190 max_fan_speed = 100 min_fan_speed = 100 min_print_speed = 10 slowdown_below_layer_time = 5 temperature = 185 [print:0.3 nozzle] avoid_crossing_perimeters = 0 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 60 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 50% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0 fill_angle = 45 fill_density = 60% fill_pattern = concentric first_layer_acceleration = 0 first_layer_extrusion_width = 200% first_layer_height = 0.24 first_layer_speed = 30 gap_fill_speed = 20 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 20 interface_shells = 0 layer_height = 0.2 max_print_speed = 80 max_volumetric_speed = 0 min_skirt_length = 20 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 30 perimeters = 3 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 6 skirt_height = 1 skirts = 1 small_perimeter_speed = 15 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 20 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 60 support_material_threshold = 0 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0 top_solid_infill_speed = 15 top_solid_layers = 3 travel_speed = 130 xy_size_compensation = 0 [print:0.3 nozzle] avoid_crossing_perimeters = 0 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 60 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 50% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0 fill_angle = 45 fill_density = 60% fill_pattern = concentric first_layer_acceleration = 0 first_layer_extrusion_width = 200% first_layer_height = 0.24 first_layer_speed = 30 gap_fill_speed = 20 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 20 interface_shells = 0 layer_height = 0.2 max_print_speed = 80 max_volumetric_speed = 0 min_skirt_length = 20 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 30 perimeters = 3 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 6 skirt_height = 1 skirts = 1 small_perimeter_speed = 15 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 20 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 60 support_material_threshold = 0 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0 top_solid_infill_speed = 15 top_solid_layers = 3 travel_speed = 130 xy_size_compensation = 0 [printer:0.3 nozzle] bed_shape = 0x0,177x0,177x148,0x148 before_layer_gcode = end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; make sure the bed is turned off\nG28 X0 ; home X axis\nM84 ; disable motors\nM107 ; fan off \n extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.3 pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 0 retract_length = 1.5 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nG1 Z5 F5000 toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0
Re: Gaps between perimeter and infills September 02, 2016 09:57AM |
Re: Gaps between perimeter and infills September 02, 2016 10:29AM |
Re: Gaps between perimeter and infills September 04, 2016 02:18AM |
Re: Gaps between perimeter and infills September 04, 2016 04:14PM |
