PETG and supports
September 15, 2016 03:39AM
Hi folks,
I've been using petg for a while now and love it.
But i still haven't been aable to generate supports in either slic3r or kisslicer
that seperate as easily as abs or pla. Usually it is the top horizontal or
near horizontal surfaces that are glued to the model.
Has anyone come up with settings for slic3r or kisslicer that lets petg
supports come away easily?
Many thanks,
Andrew
Re: PETG and supports
September 15, 2016 11:31AM
I use Simplify 3D with PETG and the supports were no harder to remove than for PLA. So it's not inherent to the PETG.
September 16, 2016 02:29AM
Umm,
Thanks for that. I had been wondering if it is a slicer issue.
Do you use a bed fan?
September 17, 2016 10:05PM
No part fan.
September 18, 2016 08:18AM
think that s3d uses 2 empty layers between interface material and the part by defaut if that helps any
If you need some help, or don't understand what I just said, feel free to send me a PM anytime
Printer: Prusa i3, 2 E3D v6 Hotends, Arduino + RAMPS 1.4 with a Bypassed 5V Regulator, 400w Insignia ATX PSU, Custom Designed Bowden Extruders
September 21, 2016 11:54PM
Appreciate the help everyone.
I think I might have to give up on kisslicer and slic3r and buy simplify3d.
I've stepped the z spacing in kisslicer from 0.2mm to 1.2mm and seen no difference.
I've changed the extrusion factor for the support down to 0.4. No difference but
it seems to affect the extrusion factor for the main model.
Very frustrating. If I could get the supports to work I'd be using PETG only.
Andrew
