Hi,I designed a filament guide for the top of an 8mm acrylic I3.
The bottom 7/8th of the print is fine,but the top part is seriously deficient,with incomplete infill and perimeters.
What could cause a problem like this?Slicing?(Slic3r)
The printer is an Aurora I3,fitted with a Wade's extruder,J-head hotend (genuine hotends.com) with 0.4mm nozzle.
Printed in 1.75 PLA at 185 degrees hotend,50 degrees bed,blue tape on aluminium bed plate.
Ramps 1.4 electronics running Marlin.
Just for the record,here is the STL file:[
www.thingiverse.com].
Btw.,I calibrated the extruder recently,which supposedly set the feed correctly.
Edited 1 time(s). Last edit at 09/24/2016 01:57AM by clogs51.
