Very odd printing problems December 12, 2016 03:44AM |
Re: Very odd printing problems December 12, 2016 06:55PM |
Re: Very odd printing problems December 30, 2016 04:50AM |
Re: Very odd printing problems December 30, 2016 05:12AM |
Re: Very odd printing problems December 30, 2016 05:15AM |
Re: Very odd printing problems December 30, 2016 06:43AM |
Re: Very odd printing problems December 30, 2016 07:07AM |
Re: Very odd printing problems December 30, 2016 10:23AM |
obewan
When you say 'solid' infill, is that 100% infill,
Have you tried reducing to say, 95%.
Re: Very odd printing problems December 30, 2016 02:47PM |
anvoice
Z axis not moving far enough doesn't explain why the center section turns out ok, or why your 40mm high solid cylinder doesn't fail. You could check for that though, at least partially, by (1) measuring the height of your objects with calipers to make sure they aren't too short or (2) taping a pencil to your extruder horizontally and drawing a line on a vertical object with a piece of paper glued to it, then measuring the length of the line and comparing to the distance you told it to move. That would give indication whether you might indeed be missing steps, unless it corrects itself which seems unlikely.
Did you try changing layer thickness? Perhaps with thicker layers you can ascertain whether it's the head dragging.
Another thing I'd try is building a calibration tower (something like a 20x20mm thin wall square) next to your print.
Re: Very odd printing problems December 30, 2016 02:48PM |
Re: Very odd printing problems December 30, 2016 02:50PM |
JamesK
obewan
Yes, sounds like over-extrusion to me, and on the 100% fill layers the only place for the excess to go is out the sides.
Alexander, have you done the fine extruder calibration as described on the following page: [reprap.org]
Re: Very odd printing problems December 30, 2016 02:58PM |
Re: Very odd printing problems December 30, 2016 04:36PM |
Re: Very odd printing problems January 03, 2017 11:10AM |
Re: Very odd printing problems January 03, 2017 01:33PM |
MCcarman
Some thoughts:-
Re: Very odd printing problems January 04, 2017 07:51AM |
