adhesion problem and poor printing quality December 19, 2016 05:04AM |
Re: adhesion problem and poor printing quality December 19, 2016 09:34AM |
Re: adhesion problem and poor printing quality December 19, 2016 09:43AM |
Re: adhesion problem and poor printing quality December 19, 2016 10:30AM |
Floyd
Looks like your printing too high for the first layers and maybe the rest of the layers.
What is your nozzle size?
What is your layer height?
Re: adhesion problem and poor printing quality December 19, 2016 10:57AM |
Re: adhesion problem and poor printing quality December 19, 2016 07:04PM |
I tried to fix auto bed leveling also, but the auto bed is ok.Quote
sliceheart
If small is OK then the bed is not leveled
Re: adhesion problem and poor printing quality December 20, 2016 02:13AM |
Re: adhesion problem and poor printing quality December 20, 2016 02:14AM |
Re: adhesion problem and poor printing quality December 20, 2016 02:19AM |
Re: adhesion problem and poor printing quality December 20, 2016 03:47AM |
Sorry, but no. This is just a matter of giving the part time to cool before printing the next layer. Using a fan might work if you have only a small tip of an object left to print, but if it is only a local element the fan will wrack havoc. The old method of just pausing between layers to give the part a minimum time to cool is enough.Quote
nebbian
This print shows clearly why the old advice to "never use a fan when printing ABS" is wrong. You need a fan to be on when printing fast layers.
Re: adhesion problem and poor printing quality December 20, 2016 04:42AM |
nebbian
Here are my settings for the fan speed on ABS. Depending on the part you can also keep the fan always on, but ensure that the speed is set so that the fan is just ticking over.
Fan speed:
Min: 10, max 50
Bridges fan speed 8
Disable fan for the first 4 layers.
Enable fan if layer print time is below 10 seconds
Slow down if layer print time is 8 seconds
Min print speed 10 mm/s
Re: adhesion problem and poor printing quality December 20, 2016 05:26AM |
Re: adhesion problem and poor printing quality December 20, 2016 05:38AM |
Re: adhesion problem and poor printing quality December 20, 2016 05:59AM |
Re: adhesion problem and poor printing quality December 20, 2016 06:58AM |
Re: adhesion problem and poor printing quality December 20, 2016 07:53AM |
Re: adhesion problem and poor printing quality December 20, 2016 08:18AM |
Re: adhesion problem and poor printing quality December 20, 2016 10:42AM |
MCcarman
I don't use autoleveling or Marlin but just check you have the offsets set correctly.
The sensor to nozzle z offset is particular for the auto levelling but not related to the 1st layer height.
However the Z offset in slicer is the distance between the nozzle and the bed at 0 height. Slicer compensates for this in calculating the Z height it will request in the Gcode. If Marlin has an equivalent offset then I would expect you need to set the slicer value to 0 to avoid double counting. So if slicer has 0 offset then a 0.25 layer height should be at position 0.25mm. This implies it is possible for the nozzle to touch the bed which is not desirable.
If you set the z height via the controller to 0.25 (same as layer requested in slicer) then this will not include slicers z offset - check what is in slicer (including the sign).
I also have black parts that have similar lumps on them so don't panic - its a combination of the material and water absorption - that's another story.
Your early photos looked like you had something loose as the layers don't seem repeatable. newer picks seem OK.
Re: adhesion problem and poor printing quality December 20, 2016 02:09PM |
Re: adhesion problem and poor printing quality December 21, 2016 05:22PM |
Jan-Willem
Have you tried printing the first layer a bit slower? Then you give it a bit more time to bond to the bed.
Re: adhesion problem and poor printing quality December 22, 2016 04:59AM |
Re: adhesion problem and poor printing quality December 22, 2016 08:07AM |
Jan-Willem
Great that you are now able to print. I think you still have some strange first layer settings. In your first picture I can see the second layer as well so it is definitely under extruded. Which software do you use and can you make a screenshot of your setting page?
Since I don't have a pic of your prusa i3 it is hard to say. But I can try.
Is there any play in your hotend mounting?
How straight are your z axis? I replaced my 5mm threaded rod with M8 acme rod and that made it a lot better.
I think you can lower your temperature a bit. I print pla at around 180 degrees. Again adjust the temperature during printing and see what happens. Also try changing print speeds during printing, then you will learn what impact temp and speed on your prints and you will recognize problems better in future.
Jan-Willem
Re: adhesion problem and poor printing quality December 22, 2016 10:57AM |
Re: adhesion problem and poor printing quality December 22, 2016 01:48PM |
Jan-Willem
ok, What are your results with first layer set to default?(so 0->200% extrusion)
I found this thing really helpful to reduce the z wobble: [www.thingiverse.com] but then modified for a M8 nut. If you send me your email via pm I'll sent you my file.
