printing issue January 10, 2017 09:10AM |
Re: printing issue January 10, 2017 12:05PM |
Re: printing issue January 10, 2017 01:33PM |
Re: printing issue January 11, 2017 06:44AM |
Re: printing issue January 11, 2017 07:07AM |
Re: printing issue January 11, 2017 08:24AM |
Re: printing issue January 11, 2017 11:49AM |
Re: printing issue January 11, 2017 11:58AM |
Re: printing issue January 11, 2017 06:12PM |
Re: printing issue January 12, 2017 08:07AM |
Re: printing issue January 12, 2017 09:01AM |
Re: printing issue January 12, 2017 09:21AM |
Re: printing issue January 12, 2017 10:37AM |
Re: printing issue January 13, 2017 04:43AM |
Re: printing issue January 13, 2017 07:21AM |
Re: printing issue January 19, 2017 12:31PM |
Re: printing issue January 19, 2017 06:57PM |
Re: printing issue January 20, 2017 02:26AM |
drwatsont
yes o_lampe i had to put a washer to align everything....a very thin one...i was getting good printings until my printer started to print outside of the object area,why this happens?
Re: printing issue January 20, 2017 07:31AM |
Re: printing issue January 22, 2017 08:05AM |
Supermec
First check the gcode file and see what the printer is being told to print. Let us know what you find.
Re: printing issue January 22, 2017 08:06AM |
o_lampe
drwatsont
Looks like the nozzle bumped in the part and skipped some steps. This can happen from over extrusion or blobs from oozing. Check your e-steps and retraction settings.
Re: printing issue January 22, 2017 03:39PM |
Re: printing issue January 24, 2017 09:37AM |
Re: printing issue January 24, 2017 12:31PM |
Re: printing issue January 24, 2017 01:58PM |
Re: printing issue January 25, 2017 06:54PM |
Re: printing issue January 26, 2017 08:18AM |
Re: printing issue January 26, 2017 11:55AM |
MCcarman
There are other methods but the simplest way to look at the Gcode is to. Hang on better go back a step.
After you have sliced your model and generated the Gcode save the file.
Then if using windows open notebook, (Start menu > programs >Accessories). In notebook select open file, then browse to the Gcode file, (change the view to all files or it wont be visible).
The Gcode file is just text so any word processing software can open it.
Note:- The saved Gcode includes comments. If you "save for SD" these and a few other things are removed so the file is smaller. There should be no difference in the actual Gcode.
Re: printing issue January 30, 2017 06:38PM |
