Filament Change
Posted by stevep12
Filament Change
January 11, 2017 06:11AM
Hello All, Has any one enabled the filament change option using a REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER ??
I have uncommented the line as required in marlin but the option is not on my Lcd controller, any advice would be appreciated ....stevep
Re: Filament Change
January 12, 2017 10:13AM
Yeah. Marlin, you mean?
Filament change is not very well documented.
The command shows when printing, at the bottom of the 'tune' menu.
I did this. Not saying its right but it worked for me.
config_adv.h
// Add support for experimental filament exchange support M600; requires display
//#ifdef ULTIPANEL ------------ I added the // comments to the start to make it not a condition
#define FILAMENTCHANGEENABLE --------------- I removed the // comments to enable it
#ifdef FILAMENTCHANGEENABLE
#define FILAMENTCHANGE_XPOS 3
#define FILAMENTCHANGE_YPOS 3
#define FILAMENTCHANGE_ZADD 10
#define FILAMENTCHANGE_FIRSTRETRACT -4 --------------was -2 but I needed -4 to take the pressure out of bowden
#define FILAMENTCHANGE_FINALRETRACT 4 --------------was -100 but I just pull the filament out by hand. Sometimes I don't change filament just want to pause with the head out of the way so 4 returns the filament where it started
// #define AUTO_FILAMENT_CHANGE //This extrude filament until you press the button on LCD
// #define AUTO_FILAMENT_CHANGE_LENGTH 0.04 //Extrusion length on automatic extrusion loop
// #define AUTO_FILAMENT_CHANGE_FEEDRATE 300
I got compiling faults with "extrude_min_temp" error in marlin main.cpp when I did this
so as a bodge, in
Marlin main.cpp
inline void gcode_M600() {
//if (degHotend(active_extruder) < extrude_min_temp) {
// SERIAL_ERROR_START;
// SERIAL_ERRORLNPGM(MSG_TOO_COLD_FOR_M600);
// return;
Comments// added.
Ed
Re: Filament Change
January 13, 2017 10:06AM
Thank you for the Info , i will let you know if It works........Regards.......stevep
Re: Filament Change
January 14, 2017 09:13AM
still no option on the LCD....
Re: Filament Change
January 16, 2017 08:59AM
Only after a print started, right at the bottom of the 'Tune' menu?
No?
Ed
Re: Filament Change
January 18, 2017 02:51PM
Still nothing, I will need to look into it further !!!!
Re: Filament Change
January 19, 2017 02:31AM
How annoying.
I checked again and the above are the only changes I made. That worked for 1.0.3 and 1.1.06.
Good luck with it. It is useful.
