Print shifts at EXACTLY the same points January 20, 2017 02:46AM |
Re: Print shifts at EXACTLY the same points January 20, 2017 07:41AM |
Re: Print shifts at EXACTLY the same points January 20, 2017 07:50AM |
Re: Print shifts at EXACTLY the same points January 20, 2017 08:36PM |
Re: Print shifts at EXACTLY the same points January 20, 2017 09:46PM |
Re: Print shifts at EXACTLY the same points January 21, 2017 01:20AM |
Ok, that seems to have done something. Switched x and y drivers. No shifts for now (2 prints so far), although I'm left wondering how that works. Even if y was suddenly undercurrent or the driver was otherwise failing, why did it always shift on the exact same layer? I'll report back if I find out more. In the meantime, thanks for the tip.Quote
the_digital_dentist
Try swapping drivers with one of the other axes.
Re: Print shifts at EXACTLY the same points January 21, 2017 03:24AM |
Re: Print shifts at EXACTLY the same points January 21, 2017 03:45AM |
Would make sense if I had z hop enabled... Thanks for the suggestion.Quote
o_lampe
Does your z-axis run smooth? Maybe z-hop fails at a certain height and the nozzle doesn't come down all the way. Then the nozzle would have to deal with a higher "last layer".
I'd check the lead screws for dirt.
Re: Print shifts at EXACTLY the same points January 21, 2017 02:02PM |
Re: Print shifts at EXACTLY the same points January 21, 2017 08:40PM |
Re: Print shifts at EXACTLY the same points January 22, 2017 11:13AM |
Re: Print shifts at EXACTLY the same points January 22, 2017 01:31PM |
Re: Print shifts at EXACTLY the same points January 22, 2017 01:59PM |
Re: Print shifts at EXACTLY the same points January 22, 2017 07:52PM |
It doesn't seem to stop short. Plus I see the z motors move on the problematic layer, so I doubt it's dragging through the print.Quote
obewan
If you home Z and then send a G1 Z100 does z actually move 100mm if it stops short then maybe your layer shift is due to the nozzle dragging on the previous layer
