Anet A8 Printer acting weird when send in a print??? January 26, 2017 01:54AM |
Re: Anet A8 Printer acting weird when send in a print??? January 26, 2017 03:57AM |
Re: Anet A8 Printer acting weird when send in a print??? January 26, 2017 12:51PM |
Re: Anet A8 Printer acting weird when send in a print??? January 26, 2017 03:28PM |
Re: Anet A8 Printer acting weird when send in a print??? January 26, 2017 04:20PM |
Re: Anet A8 Printer acting weird when send in a print??? January 26, 2017 09:07PM |
Supermec
Cura is a slicer program not firmware, but if you don't know this you are unlikely to have changed the firmware.
The Z axis should not take off like a rocket after hitting the Z endstop. Open the gcode file in a text editor and post the first 30 lines so that I can have a look at them please.
Re: Anet A8 Printer acting weird when send in a print??? January 26, 2017 09:36PM |
Floyd
I bet he didnt look at the start Gcode in Cura.
Agreed, post the first part of the gcode file with the setup info. I bet you have a move command in there.
I believe Cura default is
G28 X Y
G28 Z
G1 Z15
If you motor steps per mm are off then it might cause the Z axis to move very fast like that.
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 01:27AM |
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 03:50AM |
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 09:27AM |
cam100100
Finally got somewhere it seems to work now for some reason but now I have the problem where the hotend extruder doesn't seem to push the filament at all but it works if I manually push it into the hotend as seen in this video:
https://www.dropbox.com/s/k1nxqtzfsheofvb/20170126_220851.mp4?dl=0
Does anyone know why and how to fix?
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 09:50AM |
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 11:14AM |
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 11:40AM |
Re: Anet A8 Printer acting weird when send in a print??? January 27, 2017 11:46AM |
Re: Anet A8 Printer acting weird when send in a print??? January 28, 2017 04:04AM |
Floyd
Just for E (extruder)
Again... Cura has NOTHING to do with firmware.
Cura just slices the file you want to print. Firmware is what is loaded onto your controller board and that has all the parameters on how to behave.
Re: Anet A8 Printer acting weird when send in a print??? January 28, 2017 05:22AM |
Re: Anet A8 Printer acting weird when send in a print??? January 28, 2017 05:27AM |
Re: Anet A8 Printer acting weird when send in a print??? January 28, 2017 03:27PM |
Re: Anet A8 Printer acting weird when send in a print??? January 28, 2017 03:35PM |
Re: Anet A8 Printer acting weird when send in a print??? January 28, 2017 04:13PM |
cam100100
obewan
can you post a copy of your eeprom settings, useing repetier host press alt-E then export data
How would I find that when I press alt-E it doesn't do anything.
Re: Anet A8 Printer acting weird when send in a print??? January 29, 2017 12:08AM |
Re: Anet A8 Printer acting weird when send in a print??? January 30, 2017 02:35PM |
Re: Anet A8 Printer acting weird when send in a print??? January 30, 2017 08:14PM |
Re: Anet A8 Printer acting weird when send in a print??? September 30, 2020 04:44PM |
