Printing a screw and nut - a accuracy issue. February 18, 2017 08:42PM |
Re: Printing a screw and nut - a accuracy issue. February 18, 2017 10:43PM |
Re: Printing a screw and nut - a accuracy issue. February 19, 2017 05:45PM |
Re: Printing a screw and nut - a accuracy issue. February 20, 2017 03:50PM |
Re: Printing a screw and nut - a accuracy issue. February 20, 2017 06:13PM |
Re: Printing a screw and nut - a accuracy issue. February 20, 2017 09:07PM |
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 03:35AM |
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 07:26AM |
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 09:08AM |
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 09:21AM |
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 11:32AM |
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 01:54PM |
Supermec
digital_dentist
I suggested the formulae as starting points, rather than start from nowhere, which is what you advocate.
Supermec
Why should a change of extruder calibration change the adjustment factors (or fudge factors as you refer to them)? The extruder is either calibrated to extrude correctly, or it is not calibrated to extrude correctly. I have not suggested these formulae as a means to correct for this aspect.
It is easy to stand on high and criticise and state that the formulae are a waste of time. What I offered was some constructive advice to the inexperienced in order to give them a starting point. Furthermore there is nothing in what I have said that is incorrect.
Re: Printing a screw and nut - a accuracy issue. February 21, 2017 04:34PM |
Re: Printing a screw and nut - a accuracy issue. February 22, 2017 12:41AM |
Re: Printing a screw and nut - a accuracy issue. February 22, 2017 12:00PM |
