I use Cura as it so quick and simple to play with. However, there is one thing that has always bugged me and I haven't a clue whether there is a simple solution, so I thought I would try here and see if there is.
Pic is attached as an example. In short, where I have multiple horizontal surfaces, only the top one is handled as being the 'top layer' by Cura. I make a lot of model parts and they have small protrusions. As you can see in the pic, the main flat surfaces are hatched. The tops of the very uppermost surfaces get a smooth surface.
Is there a way to get a smooth surface on horizontal surfaces that are below the top layer?
open |
download -
(96.8 KB)
