Printing issue: too much plastic? too little? too hot? all of the above? March 04, 2017 08:46PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? March 06, 2017 06:42PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 03, 2017 01:17AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 03, 2017 11:27AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 03, 2017 06:52PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 03, 2017 07:07PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 04, 2017 01:53AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 05, 2017 12:20AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 05, 2017 08:46AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 06, 2017 01:54AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 06, 2017 07:24AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 12, 2017 11:48PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 14, 2017 04:08AM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 14, 2017 12:43PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 16, 2017 07:00PM |
Plasteroid
Perhaps my glass is 0.05mm or more curved, but I do not have so bad problems or almost none. Some shop may have a "100%" straight stone table. I don't know about usual glass sellers, cutters. But a good provider from internet? This can be something other, because your flat print image does not looks so very awful.
Hmmm. And do you use print cooler?
seattle_phil
If you do 3 way mesh bed leveling, what are your offsets? As I understand it, mesh leveling should handle most situations. I'm using "heavy duty glass" (3/16" iirc) from ACE hardware and, between it and my bed, it's off by about 0.5mm with no problems due to that. Thinner glass will bend if your underlying bed is significantly off from flat.
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 17, 2017 09:56PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 18, 2017 10:53AM |
seattle_phil
I use 9 point (3x3) bed leveling - Marlin 1.1.0 rc3. Can you opt for 3x3? That would catch a bulge in the middle.
Re: Printing issue: too much plastic? too little? too hot? all of the above? April 18, 2017 12:15PM |
Re: Printing issue: too much plastic? too little? too hot? all of the above? June 09, 2017 09:24PM |
