Expected print speed for Diamond Hotend May 24, 2017 04:09PM |
Re: Expected print speed for Diamond Hotend May 25, 2017 02:32AM |
Re: Expected print speed for Diamond Hotend May 25, 2017 08:29AM |
o_lampe
I found filament temp was critical with the Diamond. A light breeze from the part cooler and the extruders started skipping.
I then insulated the cone with cotton wool pads and Kapton tape, but it is difficult to make it stay in place. I glued the cotton wool to the hotend with silicone, but the pad fell apart after some weeks.
A silicone hood might be the best option.
Re: Expected print speed for Diamond Hotend May 25, 2017 04:59PM |
Re: Expected print speed for Diamond Hotend May 25, 2017 05:19PM |
deckingman
12mm/sec extrusion rate is pretty dammed good. If you are trying to push filament through that fast, no wonder the force is high.
Assuming 1.75mm diameter filament the area is about 2.4 mm^2 so at 12mm / sec that's around 28.9 mm^3 per sec. The best you could hope for on something like an E3D V6 is about 15 mm^3/sec and on a volcano it's about 40 mm^3/sec. So your getting almost twice what a standard E3D V6 can give but slightly more than half what volcano would give you.
My maths may be a little off but if you have a 0.4mm nozzle, the area is about 0.12mm^2. If you use a layer height of 0.3mm then the volume of the filament bead is about 0.036mm^3 so if can melt it at 28.9mm^3/sec then you could theoretically print at (28.9/0.036) = 802mm/sec.
So with "normal" feedrates of around 5 to 7 mm/sec you'll still be good for 100mm/s plus (depending on you nozzle size and layer height). I get best results with PLA at 190 deg C which I know is at the low end, but happily print all day long at 90mm/sec. Oh, and I open up my nozzles to 0.5mm. That might not sound a lot from 0.4mm diameter to 0.5mm but it equate to about 58% bigger area. So if my maximum print speed is 90 mm/sec, then a 0.4mm diameter nozzle should be good for 135 mm/sec @0.3mm layer height.
HTH
Ian
Re: Expected print speed for Diamond Hotend May 27, 2017 10:58AM |
Re: Expected print speed for Diamond Hotend May 28, 2017 05:32PM |
deckingman
Oh sorry, but you did say feed rate which implies filament feed rate not print speed. Also, that is so slow that I was assuming you meant extrusion speed.
In that case, you have something very seriously wrong. A partial blockage is the usual culprit. Do you get the same with all 3 inputs? I've only ever had this happen once, just after I assembled a new one. The fix for me was to heat the hot end, then holding a 0.4mm drill bit in a pin chuck, poke it up the nozzle towards each of the three heat sinks. If you are careful, you'll be able to locate and probe all three holes. You'll need to keep removing filament from the drill bit as it'll set. Of course, it doesn't need to be a drill bit - some other 0.4mm diamater wire would work too.
Re: Expected print speed for Diamond Hotend May 29, 2017 01:58AM |
Re: Expected print speed for Diamond Hotend May 29, 2017 09:16AM |
Mikexx
deckingman
Thanks, I'm fairly new with all this and I find some of the terminology not so obvious!
In the end I dismantled the whole thing, cleared the heatsinks and dipped the hotend itself into some dichloromethane which after an day of soaking has completely cleared all of the PLA. I can see light at the end of all 3 holes!
The hole looks smaller than 0.4mm and I have access to pin-drills which I intend to use to better gauge the actual hole sizes.
If I use a 0.4mm drill to probe all 3 holes and break through, won't this enlarge the exit hole due to the angle of the 3 holes to the vertical?
What sort of print speed do you get with yours, what sort of speed should I expect?
Many thanks again.
