Nozzle cleaning
May 29, 2017 12:15AM
A tip:
sometimes my nozzle gets clogged, resulting in jammed filament and lost print.
To resolve that, or to prevent that, I now clean the nozzle before every long print and it helps.
I use acupuncture needle to do so,
My acupuncturist gave me a set of 0.3mm needles.
When clogged, I heat up the nozzle to 250 degrees , lower the table, remove the filament from the feeder and insert the needle from the bottom completely into the nozzle.
This works. When move it up and down a few times and retract all the way, you will have molten plastic on the needle, which removes easy when cold, by pulling it through a set of closed pliers.
Warning: be carefull, they are very sharp and you easyly hurt yourself in the proces (also by the hot nozzle).
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
