Switched BACK to Direct Drive Extruder grinds filament. June 22, 2017 03:01PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 22, 2017 03:44PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 22, 2017 03:58PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 23, 2017 01:58AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 23, 2017 10:59AM |
o_lampe
Printing at 30mm/s doesn't mean the extruder pushes filament at 30mm/s through the nozzle. G1 E100 F1800 is likely to fail on all printers I know.
BTW: did you tune the PID settings for your hotend?
Re: Switched BACK to Direct Drive Extruder grinds filament. June 24, 2017 11:18AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 27, 2017 06:33PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 28, 2017 02:34AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 28, 2017 11:04AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 29, 2017 02:59PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 30, 2017 11:04AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 30, 2017 01:18PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 30, 2017 01:30PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 30, 2017 01:33PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. June 30, 2017 02:06PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 01, 2017 03:03AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 01, 2017 09:19AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 01, 2017 02:42PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 01, 2017 08:30PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 01, 2017 11:40PM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 02, 2017 02:28AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 02, 2017 09:03AM |
o_lampe
You could extrude in free air and measure the diameter.
Re: Switched BACK to Direct Drive Extruder grinds filament. July 12, 2017 10:52AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 12, 2017 11:20AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 12, 2017 11:25AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 13, 2017 10:38AM |
Re: Switched BACK to Direct Drive Extruder grinds filament. July 21, 2017 03:17PM |
