Layers 2-5 form a gap September 23, 2017 02:10PM |
bed_temperature = 94 bridge_fan_speed = 0 cooling = 1 disable_fan_first_layers = 3 extrusion_multiplier = 0.97 fan_always_on = 0 fan_below_layer_time = 15 filament_colour = #FFFFFF filament_diameter = 1.75 first_layer_bed_temperature = 90 first_layer_temperature = 235 max_fan_speed = 5 min_fan_speed = 0 min_print_speed = 10 slowdown_below_layer_time = 10 temperature = 235
avoid_crossing_perimeters = 1 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 30 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 45% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0 fill_angle = 45 fill_density = 30% fill_pattern = rectilinear first_layer_acceleration = 0 first_layer_extrusion_width = 200% first_layer_height = 0.4 first_layer_speed = 40% gap_fill_speed = 5 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 10 interface_shells = 0 layer_height = 0.15 max_print_speed = 80 max_volumetric_speed = 0 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 0 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 30 perimeters = 3 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 6 skirt_height = 1 skirts = 5 small_perimeter_speed = 12 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 10 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 40 support_material_threshold = 80 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0 top_solid_infill_speed = 10 top_solid_layers = 3 travel_speed = 60 xy_size_compensation = 0
bed_shape = 0x0,193x0,193x176,0x176 before_layer_gcode = end_gcode = M104 S0 ; turn off temperature\nM140 S0; turn off heatbed\nG28 X0 ; home X axis\nG28 Y0; home X axis\nG0 Y150; Pull heated bed forward\nM84 ; disable motors\n;StarWars/Imp\nM300 S1174 P401\nM300 S0 P133\nM300 S1174 P401\nM300 S0 P133\nM300 S1174 P401\nM300 S0 P133\nM300 S466 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1174 P401\nM300 S0 P133\nM300 S466 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1174 P802\nM300 S0 P267\nM300 S880 P401\nM300 S0 P133\nM300 S880 P401\nM300 S0 P133\nM300 S880 P401\nM300 S0 P133\nM300 S932 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1108 P401\nM300 S0 P133\nM300 S466 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1174 P802\nM300 S0 P267\nM300 S2349 P401\nM300 S0 P133\nM300 S1174 P267\nM300 S0 P133\nM300 S1174 P133\nM300 S2349 P267\nM300 S0 P267\nM300 S2217 P267\nM300 S0 P133\nM300 S2093 P133\nM300 S987 P133\nM300 S932 P133\nM300 S987 P267\nM300 S0 P267\nM300 S1244 P133\nM300 S0 P133\nM300 S1661 P267\nM300 S0 P267\nM300 S1567 P267\nM300 S0 P133\nM300 S1479 P133\nM300 S1396 P133\nM300 S1318 P133\nM300 S1396 P267\nM300 S0 P267\nM300 S466 P133\nM300 S0 P133\nM300 S1108 P1070 extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.4 octoprint_apikey = ..... octoprint_host = octoprint pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 0 retract_length = 1 retract_length_toolchange = 10 retract_lift = 0.1 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0
Re: Layers 2-5 form a gap September 25, 2017 07:25AM |
Re: Layers 2-5 form a gap September 25, 2017 04:20PM |
Re: Layers 2-5 form a gap September 25, 2017 05:53PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Layers 2-5 form a gap September 26, 2017 07:27AM |
Re: Layers 2-5 form a gap September 26, 2017 10:31AM |
Re: Layers 2-5 form a gap September 26, 2017 01:19PM |
Re: Layers 2-5 form a gap September 27, 2017 01:09PM |
Re: Layers 2-5 form a gap September 29, 2017 05:01PM |
# generated by Slic3r 1.2.9 on Fri Sep 29 21:20:50 2017 bed_temperature = 70 bridge_fan_speed = 0 cooling = 0 disable_fan_first_layers = 3 extrusion_multiplier = 0.97 fan_always_on = 0 fan_below_layer_time = 15 filament_colour = #FFFFFF filament_diameter = 1.75 first_layer_bed_temperature = 70 first_layer_temperature = 235 max_fan_speed = 5 min_fan_speed = 0 min_print_speed = 10 slowdown_below_layer_time = 10 temperature = 235
# generated by Slic3r 1.2.9 on Fri Sep 29 20:42:18 2017 avoid_crossing_perimeters = 1 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 60 brim_width = 5 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 50% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0 fill_angle = 45 fill_density = 30% fill_pattern = rectilinear first_layer_acceleration = 0 first_layer_extrusion_width = 150% first_layer_height = 0.3 first_layer_speed = 10 gap_fill_speed = 5 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 80 interface_shells = 0 layer_height = 0.15 max_print_speed = 100 max_volumetric_speed = 0 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 0 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 60 perimeters = 3 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 6 skirt_height = 1 skirts = 5 small_perimeter_speed = 15 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 20 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = rectilinear support_material_spacing = 2.5 support_material_speed = 60 support_material_threshold = 80 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0 top_solid_infill_speed = 15 top_solid_layers = 3 travel_speed = 130 xy_size_compensation = 0
# generated by Slic3r 1.2.9 on Wed Sep 27 00:02:43 2017 bed_shape = 0x0,193x0,193x176,0x176 before_layer_gcode = end_gcode = M104 S0 ; turn off temperature\nM140 S0; turn off heatbed\nG28 X0 ; home X axis\nG28 Y0; home X axis\nG0 Y150; Pull heated bed forward\nG0 X85; Pull X in Center\nM106 S255; turn on Fan\nM84 ; disable motors\n;StarWars/Imp\nM300 S1174 P401\nM300 S0 P133\nM300 S1174 P401\nM300 S0 P133\nM300 S1174 P401\nM300 S0 P133\nM300 S466 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1174 P401\nM300 S0 P133\nM300 S466 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1174 P802\nM300 S0 P267\nM300 S880 P401\nM300 S0 P133\nM300 S880 P401\nM300 S0 P133\nM300 S880 P401\nM300 S0 P133\nM300 S932 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1108 P401\nM300 S0 P133\nM300 S466 P267\nM300 S0 P133\nM300 S1396 P133\nM300 S1174 P802\nM300 S0 P267\nM300 S2349 P401\nM300 S0 P133\nM300 S1174 P267\nM300 S0 P133\nM300 S1174 P133\nM300 S2349 P267\nM300 S0 P267\nM300 S2217 P267\nM300 S0 P133\nM300 S2093 P133\nM300 S987 P133\nM300 S932 P133\nM300 S987 P267\nM300 S0 P267\nM300 S1244 P133\nM300 S0 P133\nM300 S1661 P267\nM300 S0 P267\nM300 S1567 P267\nM300 S0 P133\nM300 S1479 P133\nM300 S1396 P133\nM300 S1318 P133\nM300 S1396 P267\nM300 S0 P267\nM300 S466 P133\nM300 S0 P133\nM300 S1108 P1070 extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.4 octoprint_apikey = .... octoprint_host = octoprint pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 0 retract_length = 1 retract_length_toolchange = 10 retract_lift = 0.1 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = -0.25
