Weird auto levelling bug (uneven) on X axis
January 04, 2018 01:10PM
prusa i3, Marlin 1.8.3, inductive probe, heated alu bed
I have auto bed levelling set up. Recently I noticed that I can't get even first layer (you can see from image attached) - Z like jumps up at ~certain X position.
Hotend hits bed (depending on Z offset - ~-0.6 - -0.8) on X-min or prints to hight on X-max.
I tried:
- bilinear, linear, 3 point levelling
- turned bed upside down
- switched X rods left to right
- tilting bed on X axis
G29 produces:
0 1 2
0 +0.107 +0.215 +0.037
1 -0.263 -0.203 -0.388
2 -0.658 -0.580 -0.798
also
#define DEFAULT_MAX_ACCELERATION      { 3000, 3000, 100, 10000 }
#define DEFAULT_XJERK                 10.0
#define DEFAULT_YJERK                 10.0
#define DEFAULT_ZJERK                  0.3
#define DEFAULT_EJERK                  5.0
my entire Config.h gist https://goo.gl/h9fxDS
Motors don't skip; X angle against bed seems ok enough.
Please advise! Thx in advance
Edited 2 time(s). Last edit at 01/04/2018 01:15PM by ansisl.
open | download - IMG_7601.jpg (408.4 KB)
Re: Weird auto levelling bug (uneven) on X axis
January 04, 2018 01:52PM
My 3D Printers have leveling thumb screws for the corners to level with, does your 3d Printer have the same, or a way to add leveling thumbscrews.
If bolted solid could you place a wedge of some kind to raise the negative numbers to a positive number.
And I print many models with leveling number close to yours.
January 04, 2018 02:02PM
thumbscrews are there, I use them just to eyeball bed level (hence autolevelling), I did try extra tilted bed - problem persists :/
January 25, 2018 06:40AM
anyone any ideas ? :/
March 14, 2018 01:03AM
Hello there,
I just wanted to let you know that I have the EXACT same problem. I know it is a hardware issue but not sure what exactly is causing it....Still looking for a solution!
Edited 1 time(s). Last edit at 03/14/2018 01:11AM by devilmostwanted.
