Issue with ABS layers randomly not sticking
Posted by J3d
J3d
July 17, 2018 09:37AM
When printing ABS I often have something odd happening, like if there was not enough material extruded.
This occurs not at the beginning, but anywhere during the print, and if I re-print the same part from the same file it can be somewhere else, or not at all.
That is weird because the machine otherwise works very well, I calibrated the extruded length, this is printed at very sow speed (40mm/s), etc.
I really cannot see anything different when this happens.
And of course if I pull on the final part the layers detach at that (or those) weak(s) layer(s).
On the attached pictures it is visible just above the two round holes over the entire perimeter of the part, and on the left side just below the middle of the left hole.
Any idea where this comes from?
J3D
open | download - IMAG0634.jpg (165.6 KB)
J3d
Re: Issue with ABS layers randomly not sticking
July 20, 2018 06:36AM
Changing the slicer seems to have solved the problem, for now
