Stepper Motors (Z) move about 1 rotation and make a vibrating sound.
Posted by JustLooking
July 18, 2018 10:12AM
I am using the "RepRap Guru prusa i3 V1"
Clicking anything that has activates the Z motors makes this sound.
I already checked the rod that the stepper motors goes into to see if it's getting stuck, but it isn't that.
The problem started while I was still attempting to test out the extruder to see if it worked.
I'm still unsure if its a hardware or software problem, or both.
I'll drop my marlin config here if it's needed.
Re: Stepper Motors (Z) move about 1 rotation and make a vibrating sound.
July 18, 2018 10:37AM
lower you max z feed rate in firmware
ie
* Default Max Feed Rate (mm/s)
* Override with M203
* X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
#define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 }
make it
#define DEFAULT_MAX_FEEDRATE { 300, 300, 3, 25 }
July 18, 2018 10:43AM
Do you know what the Stepper current is.
Sounds like the stepper motor needs more current, below is a sample video of how to adjust he current.
[www.youtube.com]
If you still having problems after watching the video, then Post.
Electronics Technician / Computer Programmer
July 18, 2018 11:09AM
Ok, thanks.
