print quality awfull out of the blue September 21, 2020 04:55AM |
Re: print quality awfull out of the blue September 21, 2020 05:04AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: print quality awfull out of the blue September 21, 2020 05:17AM |
Re: print quality awfull out of the blue September 21, 2020 05:49AM |
snakergy
Actually my cooling fan is cooling kind of intermittently, but i thought it was beacause of some weird setting i may have made in my slicer.
As soon as i am home i will change the fan and check if another fan is working any different!
Re: print quality awfull out of the blue September 23, 2020 10:19AM |
Re: print quality awfull out of the blue September 24, 2020 02:39PM |
Ohmarinus
snakergy
I mean the cooling fan that cools down the stepper drivers/controller so not the part cooling fan.
Re: print quality awfull out of the blue September 24, 2020 02:42PM |
David J
This may be a silly suggestion - feel free to ignore it - but I have been caught out in the past with a delta, when one or two of the toothed pulley fastening screws worked loose on the motor shafts. Not enough to fall off or stop rotating, but enough to allow a few degrees of rotation, depending on where the flat of the shaft was in relation to the pull on the drive belt. This was a headache to find!
Re: print quality awfull out of the blue September 24, 2020 07:14PM |
Re: print quality awfull out of the blue September 25, 2020 11:27AM |
Re: print quality awfull out of the blue September 26, 2020 06:41PM |
Re: print quality awfull out of the blue September 28, 2020 04:34AM |
MCcarman
I have seen similar but don't know the cause.
I would suggest its an extrusion issue. I don't know which way you are printing but I think you get an under extrusion after a stop or slow print point and the stringy filament does weird things.
The diagonal faults are a bit of a clue as we see that where there is nozzle oozing. oozing being the equivalent of under extrusion.
No idea why it only does it on certain sides. May be due to the local air flow. Acceleration settings may also be an influence.
Re: print quality awfull out of the blue September 28, 2020 04:43AM |
jefbed
What kind of hot end does this printer use? I was looking at the manual and it appears to be an MK8 style. The manual suggests a limit of 260C, so I'm guessing it is a PTFE lined heat break? If PTFE, what is the condition of it? The manual also suggests printing speeds of 60mm/s with travel of 80mm/s, so it may be worth limiting your speed for testing purposes. The large z seams may be caused by back pressure in your bowden tube (acting as a spring), which may be mitigated by retracting on layer change and coasting. These are just my thoughts, trying to brainstorm a fix--hope to help or give ideas.
-JEB
Re: print quality awfull out of the blue November 12, 2020 03:45PM |
