[solved in 0.7.0] Work around for Slic3r skipping layers.
February 18, 2012 04:18AM
This is no longer needed as of 0.7.0
As I have mentioned [forums.reprap.org] an others have mentioned [forums.reprap.org] Slic3r has a bug that makes it skip layers for no apparent reason on good clean models.
The simple solution seems to be rotating the model on z by an arbitrary amount, re-save and then re-slice. I have found with some models you may need to try a few times but it seems to work.
Edited 1 time(s). Last edit at 02/27/2012 01:34AM by Sublime.
Re: Work around for Slic3r skipping layers.
February 21, 2012 10:49AM
Thanks for the tip.
What software did you successfully use to achieve that rotate trick ? Tried any that didn't work ?
February 21, 2012 03:53PM
I usually use RepG to orient my parts (click rotate on z and just move it randomly). Some times I open Blender to do it too. Both have worked. I have found using the rotate in Slic3r has some effect too, not always helpful thou.
February 22, 2012 05:30AM
Next release (don't ask me when, but soon), will make this thread very outdated ;-)
February 22, 2012 02:06PM
February 22, 2012 03:12PM
February 23, 2012 08:38AM
@Sublime, can you provide a link to the STL file you took these pictures from?
February 23, 2012 02:23PM
The gear is based on Triffid Hunters Herringbone Gears but has been modified to fit on a motor. The files have not been released to the public yet as I am still in testing so I will have to upload them here.
I have zipped it because it exceeds the forums limit. I have included my profile as well.
open | download - Gear and profile.zip (215.6 KB)
February 26, 2012 06:31AM
@Sublime, that model is reported as broken by Netfabb, and has visible glitches. See screenshot:
You mant want to repair it and retry slicing.
February 26, 2012 02:52PM
Well it has been run through Netfabb and Blender says it is manifolded and shows no errors.
To be sure I didn't upload the wrong file I downloaded it from the link above and ran it through Netfabb again.
Edited 3 time(s). Last edit at 02/27/2012 01:36AM by Sublime.
February 26, 2012 06:08PM
Sublime,
I've downloaded your zip too, and the Netfabb desktop application shows degenerated faces all around. Are you sure the zip contains the right file? smiling smiley
/tom
regards,
Tom
February 27, 2012 01:37AM
Sorry my fault. Overwrite existing files was turned off and it did not complain about it.
I have sliced the correct file and now the center part is solid from top to bottom (not sure if this is really needed).
I have marked the thread as solved as of slic3r 0.7.0
Thanks again for your hard work. Slic3r is amazing.
Re: [solved in 0.7.0] Work around for Slic3r skipping layers.
February 27, 2012 04:28AM
Thank you Sublime, I pay much attention to your precious input and feedback.
