Please check this object
April 15, 2012 12:28PM
I'm trying to slice meeple.stl [www.thingiverse.com]
and end up with very strange results with arcs all over the place:
Can anyone confirm this behaviour?
(It also happened with the whistle on thingiverse)
-Rob A>
VDX
Re: Please check this object
April 16, 2012 03:33AM
... seems to be a bug in calculating or displaying arcs.
Can you test,if it's only in the viewer or in the outputted G-code too?
Viktor
April 16, 2012 05:48PM
Disable the arcs feature, it was not really developed after its first implementation.
April 16, 2012 08:30PM
OK - I've disabled arcs (by removing the flag from the command line), but the gcode still looks funny, even with the latest 0.7.2 when I preview in pronterface. I don't have another viewer for gcode, as it won't display at all in Repetier host.
Attached is the gcode generated...
-Rob A>
open | download - meeple_export.gcode (100.9 KB)
April 17, 2012 05:02AM
I'm not so good with gcode, but what are all those G2 and G3 codes ?
What "g-code flavor" parameter are you using ?
April 17, 2012 08:41PM
The G2 and G3 codes are arcs. Even though I removed the --gcode-arcs from the command line call, gcode_arcs = 1 was still in the .ini file.
I've changed it to 0 and the arcs are gone...
-Rob A>
