Hairy parts
May 25, 2012 05:59AM
using prusa mendel jhead 0.5 PLA different temperature it's the same, fan, hot bed (but that's not the issue), i got the part correctly printed except it look like spiders done the work !
slicer 0.72 marlin
the is z retract 1mm extruder retract (same with different values)
is there normal ?
do i miss something ?
thank you
open | download - hairy.jpg (192.7 KB)
Re: Hairy parts
May 25, 2012 08:12AM
Chinese PLA ? Mine does that too (but not that much).
What is your speed ? maybe going faster for non printing moves could help.
The best solution IMO is using skeinforge and his wonderfull "comb" module, which ensures the minimum time is spent outside off the printed area of the layer.
Re: Hairy parts
May 25, 2012 08:25AM
> much).
don't know it's coming from [www.reprapbcn.com] with the prusa kit
work well other wise (but it's the same with green translucend one and pla90 from othe provider
130 mm/sec
> of the layer.
i cant make it work on my win7 and there is far too much option
I'm using slicer 0.7.2
if have to do with that, just say it's a feature (microsoft formatted mind, i know ;-) ))
Re: Hairy parts
May 25, 2012 08:59AM
I don't get any ooze with PLA or ABS and have never needed comb. Things that affect it:-
Humidity makes PLA ooze more. I work in ~50% relative humidity.
I generally reverse a bit more than 1mm. It depends on the hot end and the gear backlash. Sometimes it needs about 2mm.
The rewind speed has to be fast relative to the normal extrusion speed. Make it as fas as you can without the motor stalling and if it still doesn't work try reducing the speed.
Re: Hairy parts
May 25, 2012 09:03AM
thank you a lot
the humidity could be a pb in my country (cherbourg-normandie-france, not for nothing the use to be a movie cherbourg's umbrella ;-))
i will speed the retract
