I created a an STL file in FreeCAD-nightly using the loft tool. Slic3r doesn't produce a correct gcode file.
Since FreeCAD has got a lot of bugs regarding lofts: Where should I complain? Should I create a bug report for slic3r?
I tried slic3r stable and experimental, cannot run the git version: "Can't locate Moo.pm in @INC (you may need to install the Moo module)" I did not build with SUDO, since I did not want the build to modify my system.
Find attached the Freecad source, STL and Slic3r gcode file.
Tried in kisslicer which slices correctly. But if I wanted to use kisslicer, I 'd have to start configuring it from scratch.
thanks,
Jan
open |
download -
XCarrier-Fanholder.7z
(565.5 KB)
