Wrong Slice from FreeCAD lofts
Posted by JPT
JPT
May 11, 2014 05:17AM
I created a an STL file in FreeCAD-nightly using the loft tool. Slic3r doesn't produce a correct gcode file.
Since FreeCAD has got a lot of bugs regarding lofts: Where should I complain? Should I create a bug report for slic3r?
I tried slic3r stable and experimental, cannot run the git version: "Can't locate Moo.pm in @INC (you may need to install the Moo module)" I did not build with SUDO, since I did not want the build to modify my system.
Find attached the Freecad source, STL and Slic3r gcode file.
Tried in kisslicer which slices correctly. But if I wanted to use kisslicer, I 'd have to start configuring it from scratch.
thanks,
Jan
open | download - XCarrier-Fanholder.7z (565.5 KB)
Re: Wrong Slice from FreeCAD lofts
May 12, 2014 03:06AM
I ran that STL through Netfabb and there is a slight problem with it. It cleaned it up alright so have another look at it.
_______________________________________
Waitaki 3D Printer
open | download - XCarrier-Fanholder.rar (261.1 KB)
JPT
May 12, 2014 04:01AM
Thanks, but did not help.
Sorry, I did not mention what exactly was wrong: If you look from the bottom, you see that the the whole loft prints into thin air, because slicer omits a ring of PLA. Exactly the difference of the plate and the loft.
